Post by mawdo81 on Apr 5, 2016 19:25:52 GMT
Depends on the age of the donor etc. Check section 2 of the iva manual.
trident
Improvise, Adapt and Overcome
Post by trident on Apr 5, 2016 19:49:28 GMT
Post by ritchie624 on Apr 5, 2016 22:36:42 GMT
I think most require the cat. I have a mk2 1.8 and it does. Lots of nice parts, what shocks are they? Mike Mesiter Zeta R. What a lot of mx5 guys use nice but not cheap. Alan bowker has it on his mega Exocet too.
Post by ritchie624 on Apr 5, 2016 22:43:47 GMT
Can't find it on page 21 trident. Although now have car envy again of yours. Need to pull my finger out. My donor is a 1998 so guess I will need a cat. Atleast for IVA I have three exhausts to Frankenstein something together.
trident
Post by trident on Apr 5, 2016 22:47:10 GMT
If you donor is 1998 then yes you will. The flow chart about 3/4 of the way down page 21 shows the requirement of CAT etc. I thought you had a L reg plate on the car in one of your 1st photos.. is that not your donor?
Post by ritchie624 on Apr 6, 2016 12:50:01 GMT
The first car was one I had as a donor but then I bought the nearly finished car and the first owner used a mk 2 98. Another problem reading the forum last night that as the second owner of the chassis the original receipt is in someone else's name and I might end up with a Q plate. Got to IVA first so a while to go yet.
Post by ritchie624 on Apr 6, 2016 14:23:47 GMT
New rims look good, green paint the letter I think. Will they fit ET15 we shall see later.
Post by ritchie624 on Apr 7, 2016 14:56:30 GMT
Before and after. That will do nicely.
Post by ritchie624 on Apr 10, 2016 20:43:49 GMT
New home for the car, keep it and me dry so somewhere to work on it atleast.
Post by ritchie624 on Apr 17, 2016 18:16:10 GMT
Finally some work on the car today getting the pedals and steering column back in. Easy me thinks.... Oh no, after several hours I have figured the correct amount of spacing behind the pedal box to get it all right. Make the spacers then move on... Slow progress but great to see parts going back on.
Post by ritchie624 on Apr 17, 2016 18:17:17 GMT
Post by ritchie624 on Apr 18, 2016 15:53:55 GMT
Quick bit of advice please.. When setting up the throttle cable do you want the maximum stop to be hit on the throttle body pulley or the foot pedal stop?
Post by sparkyman403 on Apr 18, 2016 16:17:08 GMT
I would say use the peddle stop. If you use throttle body stop and there is still movement on throttle cable to peddle stop there's a chance of straining cable and possibly damaging throttle body . Well that's how I would set it up
Post by abc123 on Apr 19, 2016 21:49:11 GMT
definitely the pedal stop. the extra stress on the throttle shaft over time could cause the butterfly screws to shear.
Post by ritchie624 on Apr 20, 2016 10:01:26 GMT
Cheers for the advice guys. I will adjust accordingly.
