Post by ritchie624 on Feb 4, 2016 20:17:49 GMT
Tomorrow job before I go away. Make a huge list of things to do?
Post by gwnwar on Feb 4, 2016 20:26:27 GMT
A white board in the shop is good.. if things come to mind as working you might forget later to add. At my age it helps..
Post by pleurotus on Feb 4, 2016 20:53:24 GMT
I noticed another kit using marine/waterproof carpet on the interior.
Post by ritchie624 on Feb 4, 2016 21:31:41 GMT
I noticed another kit using marine/waterproof carpet on the interior. Not sure about that you could get water trapped, I'm going to go for a coating of some kind on all interior panels or I'm Thinking of getting some carbon fibre ones made up....
Post by jgilbert on Feb 4, 2016 23:32:37 GMT
I noticed another kit using marine/waterproof carpet on the interior. Not sure about that you could get water trapped, I'm going to go for a coating of some kind on all interior panels or I'm Thinking of getting some carbon fibre ones made up.... Good luck with the carbon ones, Lots of £££'s and you do need some specialist kit to get good quality strong panels. I made my own carbon side panels which was good fun and involved learning a new skill. However I used carbon effect covering for the floor as it was more cost effect. and a comparison of the covered floor vs real carbon (rear panel)
Post by ritchie624 on Feb 4, 2016 23:38:21 GMT
Not sure about that you could get water trapped, I'm going to go for a coating of some kind on all interior panels or I'm Thinking of getting some carbon fibre ones made up.... Good luck with the carbon ones, Lots of £££'s and you do need some specialist kit to get good quality strong panels. I made my own carbon side panels which was good fun and involved learning a new skill. However I used carbon effect covering for the floor as it was more cost effect. and a comparison of the covered floor vs real carbon (rear panel) How is the carbon covering holding up, I would have thought it would rip and tear? I have just found upol raptor spray kits on eBay a truck bed liner, this looks like a good look for the inside I might give it a trial on some spare aluminium and attack it see how it holds up. Carbon panels look great too good job.
Post by ritchie624 on Feb 5, 2016 18:14:31 GMT
So after spending several hours reading jgilbertjgilbert's build thread with much drooling and envy, (non of the photos would load after about page 16 sadly) I have decided to get my car on the road ASAP spend the summer enjoying it then strip it completely apart again and do all the things I want to do to make it my own and get things re painted and powder coated as corrosion is already rearing its ugly head again.
Post by mikeeyboy on Feb 5, 2016 18:53:19 GMT
I actually viewed this part complete Exocet. Glad it went to a good home.
There did not look to be many jobs to finish on it?
You could always get your own donor wishbones etc powder coated and swap them for the ones on the Exocet? I take it those are the corroding ones?
Post by ritchie624 on Feb 5, 2016 23:38:08 GMT
I actually viewed this part complete Exocet. Glad it went to a good home. There did not look to be many jobs to finish on it? You could always get your own donor wishbones etc powder coated and swap them for the ones on the Exocet? I take it those are the corroding ones? Yeah a few bits corroded and stuff to finish. Why didn't you go for it in the end? In my eyes it was a bargain price. I just want to build my own so I will be happy to start again. I have just scrapped the rolling PPF that I already had.
Post by mikeeyboy on Feb 6, 2016 0:18:52 GMT
It would have saved me some money but that's not what I was after. I already had a donor and after seeing it just decided I wanted to do everything from scratch 100% my own way.
You will be finished a lot faster than me!
Post by ritchie624 on Feb 20, 2016 16:21:57 GMT
I have a wheels question, the guide says 16's but I have read another post and Stuart says 15's I think. What is best, and I have spacers on the car with stock wheels but I can get the wheels in want in the correct offset for no spacers but not sure they will look right, any suggestions and advice please. The wheels are team dynamics pro race 1.2
Post by freshp5 on Feb 20, 2016 16:33:49 GMT
We put 15' on the car with 30mm spacers
Post by freshp5 on Feb 20, 2016 16:58:46 GMT
We had spacer of freaky parts mate
Post by welshy1 on Feb 20, 2016 17:34:34 GMT
If you want to run without spaces need to use a et15 wheel 15 inch I would say is perfect for a mx5. There aren't many et15 wheels out there most use et30 or above for cost etc.
When I built my exocet used standard offset wheels so got a set of 30mm spaces now run et35 alloys and still use the same spacers without issues.
Post by iparnell on Feb 20, 2016 21:10:08 GMT
I run some of Freaky Parts 28mm spacers with a ET42 on 15" rim. They seem to work well with the wheel arches and in my opinion fill them nicely. Cheers Iain
