Post by ritchie624 on Aug 9, 2019 20:50:16 GMT
Post by ritchie624 on Dec 18, 2019 13:30:56 GMT
Post by camspeed on Dec 19, 2019 9:48:46 GMT
I tried to send you a PM but it wont let me!
I think Chris L sent me a pic of the bonnet issue...I bought his Brian James Trailer (I assume he's your mate with the nice track car and the stealth car ramp in the garage at home!).
I am interested to see how you develop your car further....cheers John
Post by ritchie624 on Dec 19, 2019 9:50:23 GMT
I tried to send you a PM but it wont let me! I think Chris L sent me a pic of the bonnet issue...I bought his Brian James Trailer (I assume he's your mate with the nice track car and the stealth car ramp in the garage at home!). I am interested to see how you develop your car further....cheers John Hi john you have it bang on👍🏻 mate and work colleague I’m always willing to help and provide info.
Post by ritchie624 on Jun 10, 2020 12:30:15 GMT
How are we all attaching the instrument binnacle into the car. Seems no obvious way of doing it. I bodged for my track fay but tidying the car up now for IVA. They ipen test centres again 22nd of june too👍🏻👍🏻
Post by themorgster on Jun 11, 2020 7:14:00 GMT
How are we all attaching the instrument binnacle into the car. Seems no obvious way of doing it. I bodged for my track fay but tidying the car up now for IVA. They ipen test centres again 22nd of june too👍🏻👍🏻 I made brackets out of aluminium floor offcuts and pu’d them to the inside of the cluster and then bolted them to the column bracket.
Post by ritchie624 on Jun 11, 2020 9:37:36 GMT
How are we all attaching the instrument binnacle into the car. Seems no obvious way of doing it. I bodged for my track fay but tidying the car up now for IVA. They ipen test centres again 22nd of june too👍🏻👍🏻 I made brackets out of aluminium floor offcuts and pu’d them to the inside of the cluster and then bolted them to the column bracket. Was it secure enough at speed..?
Post by hutchey on Jun 11, 2020 11:46:00 GMT
I welded 2 tabs onto the steering column to secure with the the bottom mount on the dash, the rear is a bodge with some metal off the frame part and a rivet into the top of the pod secured with some Ali and silkaflex
Post by ritchie624 on Jun 11, 2020 11:51:25 GMT
I welded 2 tabs onto the steering column to secure with the the bottom mount on the dash, the rear is a bodge with some metal off the frame part and a rivet into the top of the pod secured with some Ali and silkaflex Sounds like most people bodge and glue then no easy way of doing it... cheers
Post by hutchey on Jun 11, 2020 11:57:46 GMT
I welded 2 tabs onto the steering column to secure with the the bottom mount on the dash, the rear is a bodge with some metal off the frame part and a rivet into the top of the pod secured with some Ali and silkaflex Sounds like most people bodge and glue then no easy way of doing it... cheers Lol, that is the easy way, really no other way round it unless you start welding more bits on but obviously can't do this after it's powder coated. Could self tapper or rivet stuff to the frame, that's the original idea on this kit anyway. As the bottom of the dash has 2 holes anyway, it was easy to weld something onto the column. It's not hugely secure with just 2 m5's and the plastic could break so adding some sort of stay at the rear makes it more stable
russhowell
Post by russhowell on Jun 15, 2020 7:27:29 GMT
i fitted an a small bonnet catch under the pod, so i can remove easily to hinge the bonnet up. See pics in my build. Simply bond an alloy section to bottom of pod with the button bit. Mount the peg section on steering column. Click and go.
Post by ritchie624 on Jun 23, 2020 9:31:09 GMT
IVA lights question. My fog and reverse are mounted on on the rear tub and they are on a 15 -20 degree ish angle. Is this an IVA fail as it says abojt being 90 degress to floor. Picture attached. I can make a bracket to bring them out if you guys think its a fail point...
Post by hutchey on Jun 24, 2020 10:03:37 GMT
Fog has to be 90 degrees to the road. Yours will fail as it is.
The others have (really stupidly) no requirements in this regard but have to be seen. Refer to the IVA manual for information, nice easy sections and details there.
Also, ask yourself what can you really see with the reverse light pointing up? This is where the IVA has another part complete action to my mind. Utter madness.
