Post by Shane on Apr 22, 2017 12:30:05 GMT
Hi Fin, sorry for delay, yes mate just bend away, I was worried about the weld aswell but seemed to be OK!
Post by Shane on Apr 22, 2017 14:26:41 GMT
It's worth noting that the powder coating on the weld will crack and expose the bare metal
Post by Shane on Apr 22, 2017 16:17:46 GMT
Post by Fin on Apr 22, 2017 17:12:56 GMT
It's worth noting that the powder coating on the weld will crack and expose the bare metal Grrr, but at least it's not visible. Next fun will be squeeeeezing the boot over the tank.
Post by ritchie624 on May 3, 2017 13:35:15 GMT
Anyone know which is the horn live/connector on a mk2.5 I removed the steering wheel to fit a snap off boss a year ago and need a horn for Mot so I was going to buy a switch from maplin, but alas I seem to forget what goes where...
Post by ritchie624 on May 3, 2017 13:36:15 GMT
Post by ritchie624 on Nov 14, 2017 15:32:14 GMT
After some help on the routing of the front brake flexi lines please pic of what the previous owner had done. But obviously no good as it contacts many bits of metal. Where have people put there’s..?
Post by ritchie624 on Nov 14, 2017 15:33:05 GMT
Post by miket on Nov 14, 2017 16:41:41 GMT
Mine are the donor ones and are bracketed to the subframe rather than the chassis.
Post by ritchie624 on Nov 14, 2017 16:52:45 GMT
Mine are the donor ones and are bracketed to the subframe rather than the chassis. Any pics..? Tying to figure out location and if my aftermarket Hel hoses are too long....
Post by miket on Nov 14, 2017 17:33:21 GMT
Sure .. -pls excuse the crusty donor (the car not me)... it was a mistake to round the ends so much - doesn't support the clip as well as it might
Post by ritchie624 on Nov 14, 2017 19:54:13 GMT
Thanks very much. Have you got any other p clips to stop it touching the wishbones..?
Post by miket on Nov 14, 2017 21:32:00 GMT
No - for me the key was getting the bracket as close to the donor's placing and angle as poss given i was using donor flex hoses. Perhaps yours are longer than stock?
Post by ritchie624 on Nov 14, 2017 21:51:58 GMT
No - for me the key was getting the bracket as close to the donor's placing and angle as poss given i was using donor flex hoses. Perhaps yours are longer than stock? Yeah, that’s what I’m thinking got some new rigid pipe so time to have a play... I will look at my other mx5 for inspiration too.
Post by ritchie624 on Nov 15, 2017 23:16:47 GMT
So after checking my mk2.5 even the standard brake hose can touch structure, what is the exact rules on this is it only whilst turning the wheel..?
