Post by Stiggy on Nov 15, 2017 23:29:52 GMT
If the flexi pipes can come into contact with moving parts such as wheels they should fail. If they can rub or touch the bones then they will wear and should fail. If attachment to the bones (perhaps a pipe clip mid way) to stop them wearing is required, they should pass provided the pipes do not pull tight on full lock or bump/droop.
Post by ritchie624 on Nov 15, 2017 23:31:44 GMT
If the flexi pipes can come into contact with moving parts such as wheels they should fail. If they can rub or touch the bones then they will wear and should fail. If attachment to the bones (perhaps a pipe clip mid way) to stop them wearing is required, they should pass provided the pipes do not pull tight on full lock or bump/droop. Cheers Stuart I will have a play with locations before I make some new brackets. I was just surprised that the stick mx5 could touch the wish bones when I checked today so will do my best.
Post by Stiggy on Nov 15, 2017 23:35:23 GMT
some have a spring around the pipe to stop it wearing
Post by ritchie624 on Aug 14, 2018 9:18:30 GMT
Returning to the fold....... So after nearly two years of zero car work I am about to commence work again. As with many other people I suspect life has got in the way of your builds. So things I have done... Fit a kitchen Fit a bathroom Move in with girlfriend Decorate three rooms Patio Garden And a few more... Then importantly covert her double garage into my man workshop👍🏻 So I also bought an old truck that needs some fixing but hoping within the next two months o will actually be back onto the Exocet🎉🎉🎉
Post by martinw on Aug 14, 2018 16:35:08 GMT
Then importantly covert her double garage into my man workshop .......many a true word!! Martin
Post by tom on Aug 15, 2018 5:59:36 GMT
You are definitely not alone! Numerous diy projects and 2 children have slowed down my project, I’m now 6 years in!
Post by ritchie624 on Aug 15, 2018 6:01:54 GMT
You are definitely not alone! Numerous diy projects and 2 children have slowed down my project, I’m now 6 years in! Get there one day....
Post by ritchie624 on Jun 26, 2019 12:37:22 GMT
Anyone know what has happened to the discount code section..?
Post by Stewart on Jul 4, 2019 21:49:05 GMT
We’re looking to resurrect it. What were you looking for?
Post by ritchie624 on Aug 3, 2019 13:44:37 GMT
We’re looking to resurrect it. What were you looking for? It was for autolink and carbuilder solutions
Post by ritchie624 on Aug 3, 2019 13:45:37 GMT
Just about to hook up the fuel lines to my mk 1 1.8 block. Anyone know which one is pressure and which return? It doesn’t seem obvious....
Post by snowbird1 on Aug 5, 2019 6:36:52 GMT
Pressure line connects to the front of the fuel rail, to check which line is pressure put each of the lines from the tank into a suitable container and run the fuel pump for a few seconds, it's a good idea to flush the line before connecting to the fuel rail anyway.
Post by ritchie624 on Aug 5, 2019 7:02:46 GMT
Pressure line connects to the front of the fuel rail, to check which line is pressure put each of the lines from the tank into a suitable container and run the fuel pump for a few seconds, it's a good idea to flush the line before connecting to the fuel rail anyway. Cheers dude, just a 12v from the battery I presume? Haven’t got to wiring yet....
Post by ritchie624 on Aug 8, 2019 10:35:06 GMT
Well this is going to be a fast and furious 7 days ahead I have a track day booked at caste Combe on the 17th so pretty much building the car in a week. I will try as update daily with pics. Currently at this stage...
Post by ritchie624 on Aug 9, 2019 17:53:25 GMT
Some advise please where have people located the radiator expansion tank on their Exocets..?
