Post by jwagner on Mar 30, 2016 6:53:34 GMT
I managed to snag a ride around Laguna Seca a couple of years ago in Mr. Canepa's 935. I've ridden with pro drivers in pro cars at speed, but this was literally staggering - at least I was after I got out a few laps later. Highlight of the trip, and maybe the year.
Post by steadfast on Apr 5, 2016 2:35:12 GMT
How did CHP go?
Post by colin on Apr 5, 2016 17:56:41 GMT
CHP approves!!! One more step closer to getting plates! Next up is Smog and Brake/Headlight adjustment.
Post by colin on Apr 6, 2016 17:21:42 GMT
Post by steadfast on Apr 6, 2016 18:17:46 GMT
Looks great. I sometimes wish I went with a race frame! Congrats!
Post by gwnwar on Apr 6, 2016 18:34:37 GMT
Nice clean looking build.. like the colors..
Post by jon on Apr 6, 2016 20:13:06 GMT
Great work. Looks clean.
Post by zeitgeist on Apr 6, 2016 23:40:22 GMT
Colin that looks really nice. Clean and crisp color scheme and details. Great job.
Post by jmills on Apr 7, 2016 0:20:10 GMT
Looks great! Well done!
Post by einy on Apr 7, 2016 0:21:47 GMT
Awesome job, man!! As others have said, color combo rocks !!!
John
Post by thestig on Apr 7, 2016 4:36:57 GMT
I like the change you made for the top cage. I did the same to mine. It is much easier to enter and exit with it that way.
Post by colin on Apr 18, 2016 19:50:14 GMT
Post by colin on May 11, 2016 21:38:30 GMT
So my clutch master cylinder died last weekend. The engagement point was starting to feel really weird as I was driving home then at a stop light I started creeping forward. I took a video of the slave cylinder as I pump a couple times then hold my foot on the floor. Looking at the reservoir I could actually see it go up a little as the fluid leaks past the piston and back up into the reservoir. I ordered a new master and slave cylinder to be safe as well as the extended stainless clutch line from 949Racing, hopefully they get here before the weekend. I also ordered some ARP extended wheel studs since I didnt like running spacers with the stock studs. The fact that they only had 4 or 5 turns seemed pretty sketch. It probably would have been fine, but thats not a failure I would like to have on the track. Anyone installed these before? All the videos online show people pulling them on with a lug nut, but on the 949 website they say specifically not to do that.
Post by jon on May 12, 2016 3:19:18 GMT
Use the harbor freight ball joint tool to push the studs in. Or if you have it out of the car some press.
Also be aware that many replacement hubs have slightly different bore sizes for the studs. They may be close enough to force, but it should only be a .005" interference fit. On my timken and Dorman hubs I had to drill them.
Oem you should be fine.
Post by einy on May 12, 2016 11:47:57 GMT
Or, you can use a lug nut and appropriate size washers to 'pull' each stud in.
