Post by colin on Aug 19, 2015 19:32:08 GMT
So I dropped it off at the machine shop today. They said they can get it done in a day or two and the price was pretty reasonable. I'll be much more comfortable flogging it around a track knowing that the cylinders are all nice and clean.
Post by Luke Anker on Aug 19, 2015 19:45:54 GMT
IT's A TRAP! jk.
What did they end up recommending? Are you doing a bore over or did they say they were able to clean it up without declaring it not standard anymore?
Post by colin on Aug 19, 2015 20:16:20 GMT
They suggested going up the next size. I kinda figured I needed to since the scratches were more than just superficial. I was pretty impressed with them, Steve really seemed to know what he was talking about. It's Clarks Automotive BTW, I think you had recommended them. Any news on your chassis delivery? I had been quoted 20-25 weeks originally and I'm at 18 weeks right now so it must be getting close.
Post by Luke Anker on Aug 19, 2015 20:38:01 GMT
Oh! yeah I spoke to them about the Exocet build and had a nice convo about it. Mention it to them that you're building one as well, they seemed very interested in it. I will be dropping my head off to them soon for a preventative valve job. As for the chassis delievery, I havent heard anything. I think it should be any day now as I was quoted about the same. My guess would be I should recieve the exciting email from them with my chassis in the next two weeks. FINGERS CROSSED!
Post by colin on Oct 8, 2015 23:22:05 GMT
Just heard my frame is under construction! Can't wait to get it and start putting everything together! Also got a set of R888s wrapped around my tracklites. These look mean!
Post by gwnwar on Oct 9, 2015 1:26:42 GMT
Hope you have one of the rims in pic upside down as you have 3 treads rotating in same direction 1 the other way..
Post by colin on Oct 9, 2015 1:58:42 GMT
Hahaha! You've got a good eye! Yes, apparently they thought the car I was building had 3 wheels on the right and 1 on the left. Luckily I spotted it before I left. They are fixing it overnight and I should be able to pick it up tomorrow morning.
Post by steadfast on Oct 9, 2015 14:46:52 GMT
Awesome, another bay area kit! I'm helping someone this weekend put together his raceframe. Good luck on the build, let us know if you need help.
Post by colin on Oct 13, 2015 22:20:03 GMT
I'm about to put the cam angle sensor back in, but I didn't mark the little flange things orientation. How do I know if I'm putting it in correctly or 180 degrees out of phase? I see the little notch in one side, but I don't see the corresponding chamfer on the cam shaft. What am I missing?
Post by autopaga on Oct 13, 2015 22:28:36 GMT
You can't put in in wrong way. Only in one orientation you can put it to the end without the slit. Try put in both directions and you will see the diference.
Post by colin on Nov 10, 2015 17:35:58 GMT
Just got the frame home!!! So excited to start getting everything bolted together.
Post by jmills on Nov 10, 2015 18:34:50 GMT
When did the race frame change the bracing on the top of the cage? Interesting to see that different. One a more important note, congrats!
Post by colin on Nov 10, 2015 19:39:20 GMT
When did the race frame change the bracing on the top of the cage? Interesting to see that different. One a more important note, congrats! I ordered the frame through a race shop in Salinas called Lesher Motorsports. They were the ones who recommended It. I think they had the frame come with the top diagonal un-welded and welded it and the extra corner bracing themselves.
Post by dietcoke on Nov 10, 2015 21:49:37 GMT
More headroom that way.
Post by colin on Dec 1, 2015 1:07:37 GMT
