Post by calibuild on Apr 21, 2017 23:53:43 GMT
Push to start would be cool. If you go that route, would be great to see how you manage it. The "cheap" systems ($20) seem to still require a key to be inserted, which IMO is pointless.... probably just need to do a better search on my part.
Post by timbo on May 9, 2017 16:39:30 GMT
Sorry calibuild, a gimmicky low tech push button start which also requires the key I'm afraid. However, it does all work and can be swapped over as required: Also made some progress on fitting the cycle wings, have gone for the p clip solution as I prefer them to be removable/adjustable:
Post by gwnwar on May 9, 2017 21:35:51 GMT
Remember to drill the fender brackets put in carter pins next to the P clips to stop any side motions if things loosen up. Just a what if thing happens..
Post by timbo on Jun 22, 2017 11:23:14 GMT
Some progress on IVA-proofing the gaps between the front wheels and the chassis: I used 1.5mm ali sheet with 10mm diameter holes, took longer than expected as it's a pretty awkward shape: Major remaining jobs are: (i) replace failed water pump (ii) finish exhaust (iii) extend the top rear lights out a bit as when measuring the magic 400mm I forgot to allow for the cycle wings protruding outside the line of the wheels, oops! Tim
Post by mikeeyboy on Jun 22, 2017 11:46:24 GMT
I like the panel for filling the wheel arch, I had been contemplating something similar.
With regards to the keyless entry, for IVA I think you would need the key anyway, you need the steering lock to work?
Post by gwnwar on Jun 22, 2017 20:55:48 GMT
Panel came out great. You need to mass produce and sell.. You need to do something with the long red bolt for the bonnet locks cut and cap end..
Post by timbo on Jun 22, 2017 21:34:45 GMT
Thanks guys.
Mikeyboy, you are right, you need the steering lock (or a suitable alternative). When the start button system is connected I still need to put the key in and turn 2 notches to release the steering lock and engage the ACC, IG1 and IG2 circuits.
Gwnwar, yes, I've got to do a final adjustment on the bonnet lock then tighten, shorten and cap the bolt. On the driver's side the bolt has actually turned out to be 'inside' the panel - that side is even more awkward because of the pedal box and brake servo!
Post by timbo on Aug 22, 2017 15:37:11 GMT
Post by timbo on Feb 14, 2018 16:43:33 GMT
Quick question. Can anyone tell me what this pipe is for and do I need it? It goes from the exhaust round to the inlet manifold. It's a 1.8 from 1997. Many thanks Tim
Post by browno on Feb 14, 2018 18:45:16 GMT
That is the EGR pipe - takes a portion of exhaust gas through to the EGR valve on the back end of the inlet plenum... can take you pics of my ‘98 NA if you need any more info...
Post by timbo on Feb 15, 2018 7:41:22 GMT
Many thanks for that, Browno. Having done some digging around, I see that some people remove it and others don't.
