Post by biggunz on Aug 14, 2014 17:18:48 GMT
Pictures of the rear tub and rear lights: Just need to paint the copper pipes! Managed to get the passenger seat fitted, got a little bit of work still to do on the driver side runners
Post by biggunz on Aug 24, 2014 19:34:18 GMT
SHE'S ALIVE!!!!!!!!!!!!! Finally found what was causing the problem, the connectors inside the ecu plug for CAS were 'loose'. So managed to get them out of the plug, squeeze the connected to tighten the gap and they now fit snuggly. Connected everything up and she roared into life!!! Happiest day in the garage for ages!!! Cheers for all the help and suggestion on here! Can finally get on with all the other outstanding jobs!!! Also fitted a third aerocatch to the front of the bonnet. (Sorry for pedal bracket in the pic) Also fitted the harness, good choice of black, green would of been too much!! All in all a cracking weekend! Shaun
Post by Toed64 on Aug 24, 2014 19:54:53 GMT
YAY - CONGRATULATIONS!
Post by gwnwar on Aug 24, 2014 21:02:01 GMT
Shaun.. Great news on finding problem..
Post by snowbird1 on Aug 25, 2014 6:03:52 GMT
Good to hear Shaun, loose female connections are always difficult to diagnose. Hard to find those very small male pins to use to check insertion force.
Post by biggunz on Aug 25, 2014 6:37:18 GMT
Cheers guys! Good to hear Shaun, loose female connections are always difficult to diagnose. Hard to find those very small male pins to use to check insertion force. Yeah I think I assumed it was fine from just doing a continuity check through the plug but obviously didn't have enough contact to let current flow! Now I've gotta wrap all this wiring back up!
Post by R2S on Aug 25, 2014 10:20:53 GMT
great news. I can finally stop holding my breath every time I open your thread
mikesexocet
Junior
IVA passed and on the road!!
Post by mikesexocet on Aug 25, 2014 14:28:13 GMT
Great news :-) Bet that was an amazing feeling when it fired up!
Looking forward to seeing you on the road!
Post by mrjingles705 on Aug 25, 2014 16:31:53 GMT
Dead chuffed to see you solved it!
Post by biggunz on Sept 9, 2014 18:09:13 GMT
Been trying to decide what sort of mounts to use for the front lights. I want to use the drl/indicator combined units I've got. They can't go in the slots in the nose as the indicators would not meet IVA rules. So I was thinking of a way to mount these underneath the headlights. I thought about making a fibreglass 'box' for them to be in with the headlight bolted on top, but would've been really expensive for two 'boxes'! So on the way home today I stopped off in Maplin and picked up some project boxes for mini PCB/home electronics projects. This is what I came up with!! (Ignore the crack this will be fixed)!! Let me know your thoughts. Shaun
trident
Improvise, Adapt and Overcome
Post by trident on Sept 9, 2014 18:54:46 GMT
Hi Shaun
To be honest mate I think the box is a little too big. If you could find a smaller box then it would work. Just my first thoughts and honest opinion.
Chris
Post by donboy1983 on Sept 9, 2014 19:12:20 GMT
Post by pincherrn on Sept 9, 2014 19:21:37 GMT
Hi Shaun,
What size are your DRL / Indicators. I have something that may be of interest. I found some aerofoil section in the scrap at work. I'm using it for my headlight mounts but I should have some spare. I think it came from some shelving. I'll try and get a foto and some dimensions.
Colin
Post by biggunz on Sept 9, 2014 19:27:36 GMT
I spent all day on their website and didn't see these!!! I wanted something much thinner but couldn't find anything so just got the others to see how they looked. I think you're right too chunky!
Post by biggunz on Sept 9, 2014 19:29:19 GMT
Hi Shaun, What size are your DRL / Indicators. I have something that may be of interest. I found some aerofoil section in the scrap at work. I'm using it for my headlight mounts but I should have some spare. I think it came from some shelving. I'll try and get a foto and some dimensions. Cheers Colin They're 160mm x 50mm x 20mm Would be great to see a pic. Thanks! Shaun
