Post by ashneyder on Sept 8, 2015 18:53:47 GMT
Got the handbrake installed this weekend. Was pretty straight forward other than the fact that we didn't release adjuster enough before drilling the holes. Thankfully I had some slack on the threads at the caliper mounts so we were able to make up for it.
Post by ashneyder on Nov 30, 2015 2:07:13 GMT
So I'm still dealing with this weird idle issue. Checked all the vacuum houses that I could, seem to be fine. Read the fault codes,and the only one that comes back is the evaporating one, which makes sense. Not sure what's going on.
This was the idle back in August:
This is what is sounds like now:
Post by gwnwar on Nov 30, 2015 5:03:40 GMT
Have you checked amount of fuel in tank.. maybe put more in Is tank vented.. Gap at crank sensor .020>.059 Engine running Pull IAC connector idle should drop or eng.stop. NO IAC or harness bad.. Seals around injectors Fuel pressure at idle at fuel rail 53>61psi Condition of plugs Has EGR been removed?? Vac leak ports,hoses,intake crossover tube
Post by ashneyder on Nov 30, 2015 5:07:32 GMT
Thanks George,
I have already checked some of these and will definitely follow up on the others. The thing that bugs me is that it ran fine back in August and since then I haven't done too much to that area of the car.
Post by greg on Nov 30, 2015 12:11:22 GMT
It's colder out now. That's why it's doing this. The revving is the ECU chasing the narrowband O2 sensor. Number of things cause this as Gwnwar posted.
You may ultimately need to ditch the stock ECU and get a programmable one if you can't find the cause. The stock ECU is looking for a certain air volume which your engine is now flowing beyond its capability to correct for.
Post by ashneyder on Dec 3, 2015 2:57:57 GMT
Although it sounds tempting, I am not sure I am ready to make that investment. I'll just keep troubleshooting.
Post by gwnwar on Dec 3, 2015 8:38:51 GMT
Have you checked pulled the codes??
