Post by dewoof01 on Dec 27, 2017 17:09:10 GMT
Post by airplnmdls on Jan 3, 2018 17:30:58 GMT
Enjoying watching the videos/reading this thread! Keep it up! Good work!
Post by dewoof01 on Jan 7, 2018 1:52:01 GMT
Thanks bud
Post by dewoof01 on Jan 7, 2018 4:58:56 GMT
Picked up a torsen 4.1. Got it all painted to match the trans and engine
Post by dewoof01 on Jan 14, 2018 23:06:57 GMT
Alright got some serious progress done now that I have the motor back. Cleaned and painted the block. honed the cylinders. Got the rods and pistons reassembled. block and crank back from machinist Solvent cleaned and super cleaned the block and pressure washed with hot water. Before cleaned I flex honed the cylinder bores for the new rings Pistons and Rods all assembled and ready Masking the block off for painting Block after painting
Post by dewoof01 on Feb 21, 2018 14:48:46 GMT
Sorry been a while since my last update. Been busy. Right now the rollerskate is back together. I just received my kit from exomotive and taking a break for a couple weeks before I begin the build. FM Happy Meal Stage 1 w/ lightening flywheel Engine done! Putting the engine & trans in the front subframe Motor all painted up Painted transmission
Post by dewoof01 on Feb 21, 2018 15:01:47 GMT
Post by ragingroosevelt on Jul 19, 2018 5:27:32 GMT
Thanks. I have been in contact with Oregon dmv and our emissions testing. Oregon registration is a breeze. Basically just inspect the car exists and that you have a manufacturer certificate of origin and you are good to go. Also deq our emissions testing said they can't test a car that would be registered as a 2018 but had a 1992 ecu as the computer will prompt for a obd2 and a 2018 eco code. So they recommend a SP plate which is a special interest vehicle plate that is legal to drive on the road as long as it is mainly for racing, car shows, meets, etc. And limited street driving. This allows you to completely bypass emissions as well as alot of ticky tack things such as windshield, lights, fenders ect. Hopefully that all holds true when I go to register
Do they have any tips if you're planning to daily drive? I'm in the greater Portland area and I'm considering a build. I'll lease an electric smart car from work in the off season.
Post by dewoof01 on Nov 24, 2018 4:47:17 GMT
Sorry you asked this a while ago I just dont update this thread, just my YouTube channel and Instagram. You can register in Portland as a 2018 exomotive exocet and will have 4 years of no deq because it is a new car, after that you are screwed unless you go special interest.
