Post by chrisbucks1 on Jul 22, 2017 14:09:52 GMT
Post by gwnwar on Jul 22, 2017 17:36:14 GMT
Did you also fill the shift turret with fluid 90cc while you were servicing the trans.. Are those clamps on the steering rack boots going to be a problem with IVA.. Heavy black slip ties should work.. Nice work looking good..
Post by chrisbucks1 on Jul 22, 2017 17:47:50 GMT
Did you also fill the shift turret with fluid 90cc while you were servicing the trans.. Are those clamps on the steering rack boots going to be a problem with IVA.. Heavy black slip ties should work.. Nice work looking good.. Ah didn't think about that I will swap for slip ties good spot !!
Post by jgilbert on Jul 22, 2017 20:59:08 GMT
Did you also fill the shift turret with fluid 90cc while you were servicing the trans.. Are those clamps on the steering rack boots going to be a problem with IVA.. Heavy black slip ties should work.. Nice work looking good.. Ah didn't think about that I will swap for slip ties good spot !! Chris You will also need to cover the track rod end nuts. I used electricians gland covers.
Post by chrisbucks1 on Jul 23, 2017 10:36:06 GMT
Ah didn't think about that I will swap for slip ties good spot !! Chris You will also need to cover the track rod end nuts. I used electricians gland covers. Ah good shout will do
Post by chrisbucks1 on Aug 11, 2017 16:21:48 GMT
floors fuel lines and brake lines fitted !!!
Post by chrisbucks1 on Sept 15, 2017 13:01:27 GMT
Post by chrisbucks1 on Sept 15, 2017 13:02:19 GMT
Post by chrisbucks1 on Dec 20, 2017 10:15:09 GMT
Post by chrisbucks1 on Jan 20, 2018 10:42:18 GMT
Post by chrisbucks1 on Jan 20, 2018 10:42:53 GMT
Post by chrisbucks1 on Jan 20, 2018 10:43:30 GMT
Post by chrisbucks1 on Jan 20, 2018 10:45:20 GMT
Post by chrisbucks1 on Jan 24, 2018 10:09:29 GMT
New discs pads wheel spacers!!
Post by Stiggy on Jan 24, 2018 11:01:45 GMT
Nice build Chris BUT, the spelling is incorrect on the radiator mounting brackets, a quick left to right swap required, sorry. Not sure those springs are going to allow you a suitable ride height, have you wound them up yet?
