Post by scottmev on May 26, 2017 14:43:20 GMT
Chris,
Speak to freakyparts as he does a whole kit front to rear etc. Found this out at the Kit Car Show after speaking to him, wish we had known sooner. Oh well .......maybe an upgrade over one winter I guess?
Post by jgilbert on May 27, 2017 9:14:19 GMT
John where did you get your stainless lines for your brakes I wanted to copy your technique!! I made them up myself. Car Builder Solutions sell the hose and fittings. Think there is a MEV discount, Check out the discount thread.
Post by chrisbucks1 on May 28, 2017 6:47:08 GMT
Thanks for the advice with the brake lines. Do I need spacers on the hubs And what size ?? .
Post by Stewart on May 30, 2017 14:41:44 GMT
We can supply full braided hose kits which remove the need for the hard pipes, either that or just the corner flexis. Much easier than trying to make them yourself. We can also supply the bolt on spacers. Fit your arch stay, then put the wheel on the hub. Work out how far they need to be spaced to clear the stay and let me know. We can make any size. Easier than guessing.
Post by chrisbucks1 on May 31, 2017 8:10:31 GMT
We can supply full braided hose kits which remove the need for the hard pipes, either that or just the corner flexis. Much easier than trying to make them yourself. We can also supply the bolt on spacers. Fit your arch stay, then put the wheel on the hub. Work out how far they need to be spaced to clear the stay and let me know. We can make any size. Easier than guessing. Fantastic freaky parts I was panicking about making brake lines as I have no idea what I'm doing ! How much for the brake kit ?
Post by bignik on May 31, 2017 13:00:30 GMT
I would go for the full brake and clutch kit, i got mine from Stuart and they fit perfectly and save a huge amount of agro!!
Post by chrisbucks1 on May 31, 2017 13:28:17 GMT
I would go for the full brake and clutch kit, i got mine from Stuart and they fit perfectly and save a huge amount of agro!! Is it the same from Stuart and freaky parts ??
Post by bignik on May 31, 2017 13:55:50 GMT
Yeah I got mine from freaky
Post by theancientone on May 31, 2017 14:02:38 GMT
Is it the same from Stuart and freaky parts ?? Stewart Mutch owns Freaky Parts.
Post by chrisbucks1 on Jul 6, 2017 9:58:20 GMT
ROllerskate back together !!!
Post by eman on Jul 6, 2017 15:48:23 GMT
If you have a newer kit you might want to cut those front wishbones now before the frame goes on? As once the shocks are fitted it is a biatch!!
Post by chrisbucks1 on Jul 6, 2017 17:22:36 GMT
If you have a newer kit you might want to cut those front wishbones now before the frame goes on? As once the shocks are fitted it is a biatch!! Thanks for the advice will do
Post by chrisbucks1 on Jul 19, 2017 14:08:06 GMT
Picked up my kit but managed to knock over the fence post at mev HQ for an embarrassing collection!!!
Post by chrisbucks1 on Jul 20, 2017 7:14:29 GMT
custom brake and clutch lines from freaky parts !!!
Post by gwnwar on Jul 20, 2017 19:25:17 GMT
Those kits look like a real time saver and no headaches. Well worth the money..
