Post by colin on Jan 19, 2017 21:46:00 GMT
I like that exhaust solution! Right now mine's hitting the edge of the frame, but I haven't wanted to get a custom one done since I plan on adding a turbo at one point. How much is that costing you?
Post by phocup on Jan 20, 2017 0:03:08 GMT
Colin, I'm going 1.8 turbo as well. That's one reason you see the ghetto hack join to the stock header / downpipe instead of something more expensive. I mainly wanted to fit the original ( semi modified ) exhaust that was on my donor. That 'pipe' you see pointed out the back is simply my muffler sans tip. For everything, it cost me $140 labor and material ( new 2.25" all the way through ). If I wanted flanges, it would be an extra $40 / pair. I chose to skip this cost since its a temporary solution until the 1.8 is in and I have nice 1.8 headers.
I'm planning to come back next week to have him weld in some resonator though, so soften up the sound a bit.
The only real complaint I have is that he doesn't do mandrel bends.
Post by phocup on Jan 25, 2017 6:50:47 GMT
My first real car from 15 years ago! Somewhere under there is a set of almost new TD04H-15G that I'll soon pilfer for this build. Just confirmed that today. On a side note, after building the Exo, that engine bay doesn't look TOOOO intimidating anymore. I'll get her running one day. And .. just realized after much searching that this turbo is what came stock in the Greddy kit .. which didn't get much love.
Post by phocup on Jan 27, 2017 23:20:43 GMT
Fabbed up a little something to hold my gauges .. its not perfect but its okay for now. Thinking WT / WP / OT / FP for now just to make sure everything is okay. Boost / AFR can go closer to steering wheel later. Also will put the emergency blinker on that panel and maybe some USB chargers. Oh yeah .. and the new muffler(s) came. Best part is it comes with some silencer for Laguna days. Still waiting on the y-pipe though.
Post by phocup on Feb 7, 2017 11:08:42 GMT
Trying to chase down a strange issue with my brake light. Not the indicator in the dash, but the actual lights in the rear.
I currently have integrated trailer lights installed and wired in via trailer relay.
When the key is in the second position ( electrical on ), everything works as normal. Left / right signal. Hazard. Brake. Ect.
When I turn the car on however, the brake lights comes on and stay on. On cold start, it takes maybe 5-10s for this to happen. On warm start, its almost immediate. Even with both tail light staying on, when I try to signal, it works and flashes the correct side as expected. When I stop signaling, the light goes back to solid on.
I have checked the brake reservoir float, its not stuck. I have checked the brake reservoir sensor is plugged in. I have tested the parking brake. On / off, it doesn't seem to affect this issue.
Because everything works as expected with the engine off but electrical on, I think the wiring is correct. Kinda stuck at this point. Will play more with it later but figure I'll post up in case anyone know what the issue is.
Post by snowbird1 on Feb 7, 2017 14:11:54 GMT
Without seeing the wiring diagram it's difficult to diagnose but it seems to be related to system voltage - key on, engine off voltage is about 12V, engine running voltage goes up to 14V.
Post by phocup on Feb 7, 2017 18:31:54 GMT
Post by phocup on Feb 7, 2017 21:56:38 GMT
Keep it simple stupid. In this case I'm the stupid one. Spent the morning chasing voltag and wirign when the issue was the mechanical brake pedal adjustment. Not sure exactly what happened though. Perhaps I was right at the edge of the light getting triggered and engine vibration was enough to push me over. Issue is fixed now though.
Post by phocup on Jul 16, 2017 13:57:22 GMT
Its been a bit since I last updated this thread, but I finally am through the SB100 process and am fully street legal so I wanted to document that bit here:
Dec 21 - First DMV visit
Jan 1 - First time driving my car on the street!
Jan 31 - First CHP visit.
Feb 1 - Second DMV visit. Got my REG124
Feb X - Second CHP visit.
May 22 - First BAR visit
June 5 - first call back from BAR
Jun 20 - second call back from BAR
June 21 - third DMV visit
June 16 - third call back from BAR
July 10 - second BAR visit
July 10 - fourth DMV visit
TLDR version:
It took 7 months, 4 DMV visits, 2 CHP visits, 2 BAR visits, and a bunch of stress to get my car legal. The process is simple and straight forward, except for the game of Calvinball at the BAR. YMMV definitely.
Post by phocup on Jul 16, 2017 14:08:00 GMT
After getting my plate, the first thing I wanted to get done was my new exhaust which has been sitting around for months. In hindsight, maybe I didn't need to wait but I was already stressed going through the process and didn't want to give anyone more reason to look at my car closer. Here's the new exhaust. 3" pipe from OEM header back to twin 2.25 outlet exits muffled by dual Yoshimura Hayabusa cans. Sound clip:
Post by phocup on Jul 16, 2017 14:11:49 GMT
Yesterday pulled my 1.6 and sold it same day for $200. Not bad considering I got my donor car for $400. Good time to clean up some wiring and mount points. Hoping to get the 1.8 / torsen install done this week.
Post by calibuild on Jul 16, 2017 18:06:35 GMT
Congratulations! The 'registration' process is certainly full of variation, but that's great you made it through. Awesome to be street legal.
That exhaust looks aggressive!
Post by phocup on Jul 27, 2017 19:49:21 GMT
Finished my 99 swap today and went for a test drive .. She sure looks good .. but runs and sounds like sh*t. Actually couldn't even make it around my block. Video 1 .. #1. Squeeaaaaaally motor even with the accessory belt off. My guess is maybe timing belt needs adjustment ? #2. Some demonstration of the hesitation / idle drop issue with me playing with the throttle cable. My guess is leak in the intake air tract. We'll have to play with that a bit. #3. The worse problem of all. The slightest touch of the clutch creates a continuous knocking sound that gets worse and worse as I press the clutch down more. Car does get into gears fine. Shifts feels fine. Everything I'm researching says throw out bearing, which is brand new Timken NTN bearing. I made sure it was sliding smooth pre install and in the correct orientation. Not sure what could have gone wrong here if the throw out bearing is indeed the issue. Video 2 .. Really highlight the idle drop issue #2. Main problem seems to be with quick throttle input. #4. Tranny seems to be spraying out tiny amounts of oil. Not a huge issue right now, but perhaps need a new transmission soon especially if pulling trans for issue #3. lh3.googleusercontent.com/-yEFErwo6nPs/WXpCdDXVwdI/AAAAAAAC3F8/1SVEEhH0sjg6RnEj1wMvsnvvor_qEgYNwCL0BGAYYCw/h2220/7053849509700928775%253Faccount_id%253D1
Post by gwnwar on Jul 28, 2017 5:42:30 GMT
Sounds like TB is to tight.. Was there extra pressure pushed in tensioner before tightening it in place. Did you check bearings in idler and tension pulleys. What fuel system are you using 1 or 2 hose. What engine management system. Got fluid in trans.. TO bearing not on fork right popped off on install.. Disc in right.. What did you do to engine before install.. Check crank end play.. '99 engines known for clearance problems. see.. www.miata.net/garage/tsb/sb00-01-014r-808r2.pdfAlso this.. these are old links and engine numbers that are bad are out side of ones listed in both. www.miata.net/solo/99miatathrustbearingfailure.html
Post by phocup on Jul 28, 2017 6:46:07 GMT
Hey Gwnwar,
I'm thinking TB is too tight as well. Its the original belt on a junk yard engine that I didn't replace because I thought it looked like it was in good condition. I just loosened the tension pulley, spun it a few times, and tightened her back up. Because its late at night and the car is quite loud, I have to wait until tomorrow to start her up and test. Perhaps idler / tension pulley bearing might be bad as well. Regardless, I just ordered a new set of belt / pulley / pump / seals and will be replacing all next week.
I'm using a 2 hose fuel system ( 93 donor ) and a 99 engine. Re-used the 93 FPR on the 99 rail.
Trans full of fresh Ford MTL oil ( which I'll try to save to reuse when I pull the tranny ).
I didn't know about the crank end play issue. If I'm reading your link correctly, the only remedy if the play > .3mm s a new motor ? Ouch!
