Post by Deleted on Oct 27, 2010 9:17:35 GMT
will prob make some sort of panel after its IVA tested. sure this car will be an ongoing project. At the moment I've just used P clips and wire straps to hold it all. its out of sight when the bonnets on and cant be seen from the seated position anyway. your right though, best option is to shorted, but really dont cant to cut and reattach 50 odd wires! Wasnt going to bother with te tank initially as its hiddden by the grp, but now you've got me thinking....
Post by Deleted on Oct 27, 2010 9:19:42 GMT
Ps also planning on a proper center console so I can go with a radio, starter button and cig lighter for GPS etc.. along with hazards and fog light switches.
Post by h5ngs on Oct 28, 2010 22:19:17 GMT
Sounds good like the idea of the centre console going to have to be some loud speakers to hear any music if your planning driving with a helmet on to avoid bugs and stones in your face tho. S2000 starter buttons are nice bit expensive for the kits tho or an old focus rs one if you can find a cheap one. will be alot of work redoing the wiring but if your happy and go on give the poor old tatty fuel tank a lick of paint, seems a shame not too
Andy888
Exocet Builder
Post by Andy888 on Oct 28, 2010 22:53:25 GMT
Nice work again!
Though, I'm pretty sure that all the wiring has to be covered right up to its ends for SVA purposes. Either self amalgamating tape, spiral wrap or convoluted tubing. There is a link on the forum here for the new manual as at 18th Oct.
Oh and Savage starter buttons on ebay are much cheaper than oem Honda ones!
Post by Deleted on Oct 29, 2010 16:18:31 GMT
in that case i'll wrap the lot before i go any further just in case! thanks for the heads up. looking at tinkering with stereos and starter buttons once is passed the IVA.
Andy888
Exocet Builder
Post by Andy888 on Oct 29, 2010 16:24:33 GMT
I'm assuming this is the paragraph from the IVA manual.
All electrical cables/wires must be free from chaffing and secured at intervals of at least every 300mm unless contained in a secure hollow component.
8. All electrical components must be secure be of adequate capacity and insulated as required as to prevent short circuiting during operation.
Post by Deleted on Oct 29, 2010 16:29:16 GMT
Andy, thats the only references to electrics i can find as well. In which case im ok on the wiring front. Anyone else confirm IVA wiring rules??
Andy888
Exocet Builder
Post by Andy888 on Oct 30, 2010 16:17:25 GMT
Have a read over on locost builders forum though...
They have a thread where everyone posts their IVA fail points and some centres seem very picky about the insulation. Some poor guy was failed cos his insulation stopped an inch short of the connector. It would just be much easier to cover it all now.
Post by Deleted on Oct 31, 2010 18:10:08 GMT
another few bits done. Radiators in, again used 15mm chromed plumbing pipe as spacers also cleaned and detailed the M526 gearbox. before after
Post by Deleted on Nov 1, 2010 21:13:30 GMT
fuel pipes in as well now. spent the rest of the day changing over the shock springs to new rokkor racing 40 lower springs and detailing the dampers in red.
Post by squelch on Nov 1, 2010 22:30:21 GMT
you'll be ready for an IVA next week
Post by Deleted on Nov 2, 2010 23:35:51 GMT
Andy888
Exocet Builder
Post by Andy888 on Nov 2, 2010 23:54:17 GMT
Looking fantastic mate!! Keep up the good work and write up, it's greatly appreciated.
Post by squelch on Nov 3, 2010 0:23:08 GMT
looking good quick question, you dont have a lower rear under brace fitted (goes between the rear most bottom wishbone inner bolts ) i dont think ive every worked on a mx5 that didnt have one fitted
Andy888
Exocet Builder
Post by Andy888 on Nov 3, 2010 12:07:27 GMT
There is no kind of brace on our MX5 there either...
Alex, did you have to relocate the rear brake pipe connector box? Ours seems to not clear where the panel behind the drivers seat will be attached.
