Post by zeitgeist on May 30, 2016 2:10:29 GMT
The EGR tube connects the exhaust manifold with the intake manifold. Your arrows point to where the tube connects to the intake manifold. That tube runs behind the upper part of the head near the coil packs over to the exhaust manifold or header. I can try and get a pic of my set up in the AM here but I have a lot of hoses and brake lines with ABS running in the same area.
Post by ritchie624 on May 30, 2016 2:20:58 GMT
I have had a Google and will check out my car tomorrow. Looks like you can get egr delete kits. Also need to try and find a guide as to which hose connects where I have a mk1 engine sitting around but not the same sadly.
Post by gwnwar on May 30, 2016 5:12:59 GMT
You should have 2 hoses going to the throttle body 1 on front 1 on outside. You say no water cooler between oil filter and block with 2 hose off of it right..
Post by ritchie624 on Jun 1, 2016 12:32:43 GMT
Radiator is fully mounted and rock solid so big tick off the list today. Got a mate coming round to look at my hose dilemma shortly. But so far a very productive day.
Sparks
Junior
1999 1.8 donor
Post by Sparks on Jun 10, 2016 8:17:51 GMT
Are you all sorted with the hoses?
Welcome to come and check bits on mine, it's in 1 piece still!
Post by ritchie624 on Jul 26, 2016 18:21:28 GMT
Long time no post. A month away with work and life getting in the way.
Today has been good though water system nearly done all hoses and clamps in place, bar the radiator cap to the expansion tank, need to purchase some pipework for that.
New panel made for behind the pedals, fits nice and just need to drill and rivet.
Finally the big excitement, clutch system filled and pressure bled and I have a pedal. Good day, something actually finished on the car. The only reservation I have I the pedal has approx 2mm of travel before the stop as the pedal hits the structure, hoping this should be enough to release the clutch when it's alive. Can't space the pedal box any more as the studs for the steering column are already at max. Could always shave the pedal a tad with the dremmel, a job for when it's running I think.
Post by gwnwar on Jul 27, 2016 5:30:26 GMT
Adjust top end free play to 10mm..
Post by ritchie624 on Jul 27, 2016 8:15:45 GMT
Adjust top end free play to 10mm.. Is that winding in and out the fork end that attaches to the pedal..?
Post by ritchie624 on Jul 27, 2016 10:54:20 GMT
Really happy with the new wheel, just need a resistor for the airbag light and a horn button to be put somewhere.
Post by gwnwar on Jul 28, 2016 5:35:57 GMT
Yes loosen the nut at pedal end of rod and turn rod till you have 10mm free play secure nut..
Post by ritchie624 on Jul 28, 2016 8:07:29 GMT
Thanks again Gwnwar, where would we be without you...
Post by ritchie624 on Jul 28, 2016 16:12:30 GMT
I'm away for a few days and was going to purchase all my lights and have taken hours looking at aesthetics, position and of course IVA compliance.
I think I will fit a 3rd central brake light post IVA as I am concerned about the distance of stop light to fog.
The only problem is I am going to use square all in one, tail, reflector, Indicator, stop units and mount them to the rear cycle wings, but reading the IVA they may be to close to the ground 350mm. Can someone check the height of the cycle wings off the floor pretty please...?
Post by ritchie624 on Jul 28, 2016 16:13:08 GMT
All the units I'm going to buy below, I think they are all IVA compliant need to ring CBS and check.
Post by ritchie624 on Jul 28, 2016 16:13:38 GMT
trident
Improvise, Adapt and Overcome
Post by trident on Jul 28, 2016 20:47:31 GMT
