Post by Trenon on Oct 9, 2015 16:42:09 GMT
Picked up my chassis and bodywork a few weeks back and have been tearing down the miata since. This is where I'm at so far.
Post by Trenon on Oct 9, 2015 16:44:02 GMT
Hmm....my insert image isn't working. Fixed it.
Post by jmills on Oct 9, 2015 18:26:22 GMT
I spy an intercooler in the background. You sir, are in for a fast machine. Look into rad and intercooler fitting before you start mounting those. I had to raise the rad quite a bit (aftermarket) as many others have as well. The FM piping can be made to fit, I just posted the mods I had to make to get mine mounted without cutting the bodywork.
Enjoy the journey!
Post by Trenon on Oct 9, 2015 21:09:12 GMT
jmills did you take some pics of all the mods you needed to do to make it fit?
Post by jmills on Oct 9, 2015 21:55:13 GMT
not yet. I'll try to do that this weekend. Had to make new upper rad mounts, did some creative tube flipping and cutting, and had to modify the lower rad mounts. Once I get pics I'll update my thread on the install.
Post by jmills on Oct 9, 2015 21:56:14 GMT
I also had to do a very easy fab of new intercooler mounting brackets but that was pretty straightforward. The Flyin Miata ones are pretty tall and bend at an inconvenient point.
Post by Trenon on Oct 10, 2015 23:08:16 GMT
If you could take some detailed pics with a measurement or two I'd appreciate it.
Post by jmills on Oct 13, 2015 1:53:20 GMT
I'll get some next time I'm at the car. I haven't had time to work on it the last two weeks. New project at work, weddings and a race consumed my weekends.
Post by Trenon on Oct 16, 2015 4:34:27 GMT
Post by einy on Oct 16, 2015 12:04:26 GMT
All of the 'issues' that you note have been figured out and documented in this forum by other builders. Look back at Steadfast's build, Greg in PA's build as just two of the many well detailed walk thru's on overcoming the items you're noting above.
Post by Trenon on Oct 16, 2015 17:06:11 GMT
Full disclosure have a 2 week old baby and I was running on very little sleep when I wrote that.
I've seen what steadfast did to get the spacers to work after I bought them. I'm just a bit disappointed that they would ship them out like this. A very small design change would make it so they were a simple bolt in product...not a cut your suspension product and grind away part of their clamp.
As for the hood mount steadfast's build it looks like it sits almost flush on the frame rails. Where as I cannot get mine to sit that close. It hits the valve cover. I'll try fitting a few things a bit better and see how high it'll have to sit.
Thanks for pointing me at those builds.
Post by jwagner on Oct 16, 2015 17:28:58 GMT
The only cutting to mount the spacers on my NA8 was to trim the rear top hat bolts a bit. Aside from that the spacers fit.
Yeah, the hood fit seems to be a best-fit compromise. We're working through that now too. Don't mount your hood until you have the throttle body and intake, etc. on the car. The idle screw on top of the throttle body seems to be the worst point of interference on ours.
Post by steadfast on Oct 16, 2015 18:42:44 GMT
What engine mounts did you use? I've read that the competition ones raise the engine a few mm's. That doesn't sound like a lot but ever mm counts.
As for possibly fitting it over what you have. First you will have to cut your lower rad mounts. I'll see if I can get a few pictures for you later today. I also cut a U shaped hole on the underpart of the nose cone. I'll take pictures of that today too.
Post by Trenon on Oct 16, 2015 20:02:11 GMT
I just have the stock motor mounts.
The pictures would really help thanks!
Post by steadfast on Oct 16, 2015 23:20:41 GMT
Don't mind how dirty everything is. Here is the bottom bracket:  Here is the top bracket (which is modified to fit the raised radiator):  Here is the cut I mad on the bottom part of the nose cone:  And here is the gap that I have:
