Post by welshy1 on Jan 15, 2016 20:47:34 GMT
Nice progress there agree about being cold specially in work with the bays open ive got like 5 layers on just to keep warm.
Post by gsrflyby on Jan 16, 2016 16:54:43 GMT
Such an awesome thing to be able to share with your spouse, wish my wife was interested in the Exocet as much as I am. But, then again, we would probably live in a tide box under an overpass if that were the case.
Post by squiddy1981 on Jan 16, 2016 19:17:31 GMT
it's definatley has its benefits the biggest one is not having to make an excuse to go down the garage.
Post by gsrflyby on Jan 17, 2016 20:48:23 GMT
I bet
Post by squiddy1981 on Jan 21, 2016 14:31:53 GMT
Post by dietcoke on Jan 22, 2016 5:44:37 GMT
I have pictures of a v8 on an engine stand in my kitchen somewhere. Cleanest, brightest place to put one together. Made sense to me.
Post by squiddy1981 on Jan 29, 2016 17:26:17 GMT
just been fitting the loom down the ppf and noticed that where the ppf leaves the tunnel its touching the rear section of the frame. ive tried lifting and lowering the car from axel stands, loosening and tighten all the frame bolts and i have loosened the ppf bolts all to no avail. Anybody got any ideas?
Post by squiddy1981 on Mar 27, 2016 16:51:05 GMT
exciting day today connected the battery. turn the key and nothing. got voltage at both fuse boxes and at the headlights, but when I turn the lights on the tns relay goes a bit mad. the car did turn over on the starter though. there are no lights on the dash either.
Please help.
not sure where to go to be honest.
Post by p5curly on Mar 27, 2016 22:42:17 GMT
Re check all earth points and all connectors are clicked together firstly as a start point
Post by ikarl on Mar 27, 2016 23:05:00 GMT
Anything "immobilisery" from the original car that you may have missed?
Post by squiddy1981 on Mar 28, 2016 14:59:06 GMT
lights sorted missed the chassis to battery earth. thanks for the help.
Post by ikarl on Mar 28, 2016 17:02:11 GMT
So, did it start ok then?
Post by squiddy1981 on Mar 28, 2016 17:41:18 GMT
haven't tried starting it yet as I still need to sort the rear loom. but it did turn over on the key.
Post by squiddy1981 on May 16, 2016 9:24:19 GMT
Now that the engine is alive I'm about to pull the trigger on some wheels which are et38 the build guide says that et15 require no spacers does that mean I need a 23mm spacer?
Post by mawdo81 on May 31, 2016 17:04:51 GMT
That's the maths, you may find it easier to get 25mm or someone else might be able to advise if you can get away with 20mm. Make sure you get hub centric ones. Many use Freakyparts spacers. He's on here but I forget his username right now sorry.
