Post by mawdo81 on Jun 22, 2015 14:49:19 GMT
Hi what gearbox are you running then? I need a shifter from a gertag, and if you're running that you'll need a mk1 shifter, that I have...
Post by carlostheoptimistic on Jun 23, 2015 8:18:13 GMT
Yeah, I'm using the Getrag 6 speed box off the ST170 but unfortunately I have used the shifter for my build, I modified it to do the job. Are you interested in the clutch? you can have first dibs on it as your build thread reminded me it was still stuck in the garage
Post by ridgeback on Jun 23, 2015 17:05:19 GMT
Hi James I think I may have the shifter you require if you mean a Mk1 focus.
Post by mawdo81 on Jun 23, 2015 18:24:42 GMT
Hi ridgeback, I have a standard mk1 shifter, but in the sonic the gear cables go to the rear not the front so the direction is reversed. I understand that to keep the standard H pattern i need a mk2 mondeo or a gertag gearbox shifter. Which have you got please?
Post by ridgeback on Jun 23, 2015 18:39:02 GMT
Not sure but I have 2 different ones I still have your email address so I will send you some photos so you can see.
Post by mawdo81 on Jun 24, 2015 12:02:07 GMT
Thanks, pics received, will compare to existing levers!
Also Clutch received thanks Carlos, hoping to fit it tonight..:-)
Post by mawdo81 on Jun 25, 2015 7:42:15 GMT
Well fitting didn't happen - forgot new bolts needed for flywheel. Hopefully Burton Power will get these to me tomorrow.
On another note, does anyone know/can they measure the spec of the bolt that holds the rear caliper to the slider pin please?
Post by Johnsto on Jun 25, 2015 18:15:55 GMT
M8 x 22 10.9 graded. Hope this helps.
Post by mawdo81 on Jun 27, 2015 10:16:48 GMT
Flywheel on and torqued Clutch on and aligned, need to torque up. All parts for brake rebuild now received so that's a job for an evening in the garden.
Post by mawdo81 on Jun 28, 2015 19:53:46 GMT
Clutch manually aligned and torqued. Drive shaft bracket on and torqued. Alt bracket and alt on and torqued up.
Post by mawdo81 on Jun 28, 2015 19:54:24 GMT
Feels SO good to be putting things together instead of taking them apart/ prepping/painting
Post by kiwicanfly on Jun 29, 2015 0:12:04 GMT
Feels SO good to be putting things together instead of taking them apart/ prepping/painting Nice feeling isn't it, that's why I have dis-assembled and reassembled mine so many times
Post by mawdo81 on Jul 3, 2015 17:21:22 GMT
Nate is a star! He helped me align the gearbox and it's now back attached to the block.
Nate I can't thank you enough.
Mtx75 needs an ib5 stick, so had one off ridgeback. Tempted by a short shift kit for it, but want more details and the eBay seller is being a pita!
Have also worked out how to use my mtx75 shifters reverse protection on the ib5 shifter, just need to build a block to stop it on.
Next up, floor! Hoping that will be this weekend!
Post by nate78 on Jul 4, 2015 20:04:10 GMT
No worries fella, as I said , more than happy to help
Post by p5curly on Jul 4, 2015 20:59:46 GMT
Good to meet up today and check out your build hope we can help out if needed
