Post by martinw on Jun 15, 2016 9:31:48 GMT
RE your body panels, glad they are fitted, it's just one of those things that once you have done it and know how, it's easy. Yes, that's very true Guy. Afraid my memory wasn't up the the task of recalling just how I'd done it........! Martin
Post by Fin on Mar 18, 2017 10:04:58 GMT
Need to take pictures! Floor is on and 3/4 bolted down, that's the job for this pm but the weekends been taken up with a family wedding. Then it's a quick job to trial fit the front floor, and mark for drilling and rivnuts. Hope to flip the chassis right way up once and for all this week ? What size bolts did you use for the floor?
Post by mawdo81 on Mar 18, 2017 10:07:15 GMT
I used m4 spaced at about 150mm. When I first marked it up I did 150mm but that left it uneven so I decided where I wanted key ones (corners, joints etc) and then spaced the others evenly between them at no more than 150mm centres.
Post by Fin on Mar 18, 2017 11:49:24 GMT
Thanks. Liked the bit about the OCD and calipers
Post by Fin on Mar 19, 2017 10:36:36 GMT
Ordered M4 rivets and hex bolts, but is there anything to stop you using dome headed M4 screw/bolts?
Post by mawdo81 on Mar 19, 2017 13:56:15 GMT
For everything underneath I've used button head, just used hex on the p clips as they'll be hidden away.
Post by Fin on Mar 19, 2017 15:15:27 GMT
Didn't occur earlier, but I ordered some dome heads anyway. Aesthetically more pleasing!
Post by mawdo81 on May 16, 2017 12:19:16 GMT
Not had much of an update for a while! Need to upload some pictures but: All hardlines ran Awaiting Boss for Fuel tank/Pump Coolant system awaiting a couple of jubilee clips and clear cot on the expansion tank bracket Electrics completed - rewired the OEM battery fusebox to my (current & future) needs New bus-bar insulator 3D printed by friend at work Rear discs fitted with caliper brackets
Hoping for a test fire in the next week or so, then the panels can go on...
Post by mawdo81 on Jun 6, 2017 20:59:41 GMT
So 3 weeks have gone by with bits and pieces happening in the garage and elsewhere.
The test fire today was a dismal failure. Not hearing the fuel pump made me question fuel and surely enough the pump isn't working. It was when it came out, so I extracted it and tested it again on the bench and all worked fine. Double checking all the electrics to the pump and I'm confident the issue is a 6V drop across the relay!
The relay itself passed a bench test no problem, so there must be a corroded connection in the relay holder itself.
It's tomorrow's job to sort that, as it will make a difference to where @maz delivers the side panel on Thursday!
Post by mawdo81 on Jun 7, 2017 20:41:48 GMT
She's alive!
Bit lumpy and needed the throttle but she's been stood for 2.5 years so can't really complain.
Time to tidy up the wiring then the body can go on!
Post by buildityourself on Nov 14, 2017 21:37:32 GMT
Nice diary. Any chance of fixing the broken photobox pictures to your thread, as feel like missing half the story? how did you go about this "rewired the OEM battery fusebox to my (current & future) needs" cutting and soldering, or moving the existing pins about?
