vtR1k
I'm a trike lover...
Post by vtR1k on Mar 21, 2011 8:59:44 GMT
I don't want to spoil any good ideas, but mounting a check valve don't seem to be a good idea: - in time, it can get stuck - if it is a spring-return one, the fuel flow will not be sufficient enough to open the valve
In racing tanks there is often a kind of foam used inside the tank to keep the fuel in one place...
But I thougt about the problem too, and didn't come to an idea... yet... I do not know how much space there is for a small catch tank.
vtR1k
Post by vtR1k on Mar 21, 2011 10:09:03 GMT
Post by anglais on Mar 21, 2011 17:20:46 GMT
demo Tr1ke set up, has one r1 fuel pump after the t peice before the swril tank, then one roughly where it would be on the origanal set up, also you can see there swirl pot which i think is custom made by RTR! might have to see wether they can make me one, The diagram is great thanks, makes allot more sense to me Vtr1k if memory serves me correctly you have the injection engine which has an internal fuel pump in the tank! is that why you have three or is that what you recomend. I think one will not be suffiecnt on the bike they are effectivly gravtiy fed, is a second r1 the best option you think Thanks for the comments and encouragment on the pics Paul
vtR1k
Post by vtR1k on Mar 22, 2011 8:41:06 GMT
Correct, my I need to mount the pump inside a tank that is why I made this diagram. I thought that the former models also had this system, but it is not... For carburettor engines, Demon Tweeks can also supply the correct pump. Then you don't have to depend on gravity only. Check this: www.demon-tweeks.co.uk/Search.do?method=delegate&n=810&s=fuel+pumpcheers
vtR1k
Post by vtR1k on Mar 22, 2011 9:41:29 GMT
Post by anglais on Mar 22, 2011 20:23:47 GMT
Thanks again for your help will get that swirl pot! and have a look at the fuel pump The carb r1 bike had an external fuel pump mounted just underenath the tank.
Post by edwinwl on Mar 22, 2011 20:43:46 GMT
Me too!
Good to see that ideas come to plan. Can't wait to start my build.
Post by anglais on Mar 22, 2011 20:56:59 GMT
Cant be long now till you get them! just bought a second r1 pump on ebay at a good price, hoping by using the exact pump and the swril pot the psi will be spot on and no fuel starvation. Might need some help with a fuel pipe diagram latter though.
busy for a couple of weeks but will have time at easter to crack on , have lots of new parts on order.
vtR1k
Post by vtR1k on Mar 26, 2011 8:52:02 GMT
Post by Deleted on Mar 26, 2011 9:10:08 GMT
Thats fantastic, a good price too, I had been looking at the plastic water pipe stuff at the camping centre as its £1.99 a metre, thought it might be a good way to keep the wiring in one place, but I think although more money, this is a much better idea.
Post by anglais on Apr 20, 2011 20:31:18 GMT
Bit more progress, ended up buying a new fuel pump from ebay! one that venon pointed out! owe you another one for that. you should be able to see the pump laid out ready to be bolted to the bulk head, both tanks in and all the pipe work for the radiator attached steering all conected, both wheels on and pipe work for the brakes, waiting for a resivoir swirl tank, im confused , do i attach the top pipes from the petrol tanks to the two side outlets to the swril pots? then make breather holes??? hope that make sense, any help gratefully recived Have done a bit more on the dash, got the speedo attached, and bought a few more bits, will hopefully get a day on it over easter.
vtR1k
Post by vtR1k on Apr 24, 2011 8:25:38 GMT
Connect the lowest to the engine and the upper connection must be used as a return line to the fuel tanks. The 2 in between must be return line from engine and supply line from the tanks. Doesn't matter which of the 2 is which. As long as the engine is fed from the lowest point of the swirl tank and the upper is the return (excess fuel) to the fuel tank.
Post by anglais on Apr 25, 2011 7:55:07 GMT
ok, so the very top one is the return to the tanks!bottom goes to the engine . Do i need to put any one way valves on any thing eg the return from the engine. Each tank i will have to drill a seperate breather?
Post by edwinwl on May 2, 2011 17:09:46 GMT
Post by Deleted on May 2, 2011 17:27:31 GMT
Hiya Fella, I picked up a Kliktronic unit a while ago www.nabd.org.uk/openhouse/openhouse43/pics/kliktronic.jpgSo I have asked RTR to weld me a bracket on the chassis so I can mount it. I intend to use a pair of Tig welding paddle buttons as my shift up and down, and mount them on the back of my racing wheel on a coil telephone cable to the control box, I had thought to have a separate system in case it fails, but will take a look after its test maybe. Nick
