Post by JIDiesel on Apr 29, 2015 21:45:44 GMT
John, what fasteners did you use up towards the nose? I need to redo my front fasteners as I'm not too happy with how difficult it is to get them situated when putting on/removing the hood. I used the same fasteners that you used for the front of my hood. I did cut out a section from the bottom of the nose to make it fit around the bottom of my radiator. This allows the nose to set up higher. I also mounted bumpers to the sides of the car frame to have the hood rest on. When I put the hood on I align the rear post from the Aerocatch first then set down on the front Quik Latches. Yes, the Quik Latches were a bit of a pain to align at first. I think that having he bumpers on the corners of the frame help with the alignment and mounting of the hood.
Post by steadfast on Apr 29, 2015 21:57:32 GMT
Just so I'm understanding you correctly, you cut a section under the nose (unseen from the top) to allow you to set the hood/nose on top without sliding it into place?
Post by JIDiesel on Apr 29, 2015 22:45:19 GMT
Just so I'm understanding you correctly, you cut a section under the nose (unseen from the top) to allow you to set the hood/nose on top without sliding it into place? Yes I did. It is cut out the width of the radiator and almost the thickness of the radiator. I mounted a piece of angle aluminum across the bottom. and added some trunk weather strip to it and that rest against the radiator. The lower radiator mount is the one provided from Exomotive. I think that my hood sets about 1 3/4" higher in the front than yours.
Post by steadfast on Apr 30, 2015 2:28:31 GMT
Thanks for the pictures and explanation. I'll be doing that this weekend!
Post by JIDiesel on May 29, 2015 3:08:52 GMT
Just a little update. Have not had much time to work on the project, I have been swamped with work. Looking forward to tourist season ending finally will be able to get the project done. I have finished mounting the tail lights. Solved the fuel vent problem. Just some wiring to finish in the front.
Post by Exo81 on May 30, 2015 21:41:13 GMT
Congrats on getting tagged!!! I like the lights. I have my inspection scheduled for June 23rd. The local DMV guys make it sound like more of a formality after all the documentation stuff being so strict.
Post by Exo81 on Jun 12, 2015 13:47:51 GMT
John, where did you get your fuel fill? I'm Guessing it's from the marine world. I installed a Perko ratcheting fill and I'm just not happy with it. I like the look of the larger flange like you have. Any suggestions would be appreciated.
Bill
Post by JIDiesel on Jun 13, 2015 21:43:56 GMT
Post by einy on Jun 13, 2015 23:20:51 GMT
What do you do with the factory tank's vent hose if you use a cap like the Sparco?
Post by JIDiesel on Jun 14, 2015 0:22:35 GMT
Post by scareyourpassenger on Jun 15, 2015 17:32:26 GMT
So this lets air into the tank like the gas cap. What about venting positive pressure?
Post by einy on Jun 15, 2015 18:35:00 GMT
So this lets air into the tank like the gas cap. What about venting positive pressure? To a degree, does it need to? Typically, and especially if my garage is hot inside, if I open the (pre-disassembled) Miata's gas cap, it releases pressure in the tank. I think the factory vent hose / pipe runs to the welded assembly that comes into one unit "before" the gas cap. So, if the factory gas cap has a one way valve to let air in but not out, that'd do the same thing as the combination of parts that Jon is using. I think.
Post by JIDiesel on Jun 16, 2015 1:41:08 GMT
So this lets air into the tank like the gas cap. What about venting positive pressure? My build is from a 2000 Miata only 1 fuel line no return line. No return positive pressure in the tank. I have the fill 1/4 vent hose and the tank charcoal vent linked to the overboard marine vent.
Post by greg on Jun 16, 2015 3:20:16 GMT
Oh you put a charcoal canister in yours? I was under the impression the vent was a mini canister.
Post by scareyourpassenger on Jun 16, 2015 19:30:12 GMT
So this lets air into the tank like the gas cap. What about venting positive pressure? My build is from a 2000 Miata only 1 fuel line no return line. No return positive pressure in the tank. I have the fill 1/4 vent hose and the tank charcoal vent linked to the overboard marine vent. I am not sure this solves all the issues that the OEM design was able to. Overpressure is the evap and charcoal canister and the gas cap was allowing air into the tank to replace the space the fuel occupied. Fuel exit and return doesn't really matter from a regulation standpoint, it just contributes to the issue. I would think with the way it is setup there would be positive pressure in your tank on a hot day or if the car sits for a while. I am not sure how much it matters but I would think Mazda addressed it for a reason.
