Post by ssmith764 on May 4, 2015 15:52:29 GMT
Thanks Chizzy. I feel a bit more confident now. Cheers
Post by sandancer73 on May 4, 2015 19:12:40 GMT
The engine cover catches may fail, mine got changed to screws.
Post by ssmith764 on Jun 8, 2015 18:31:39 GMT
Big day tomorrow! Fingers crossed
Post by mawdo81 on Jun 8, 2015 18:54:50 GMT
Good luck and let us know...
Post by chizzy on Jun 8, 2015 20:28:42 GMT
Good luck mate
Post by carlostheoptimistic on Jun 8, 2015 20:38:18 GMT
Good luck and lookin' good.
Post by ssmith764 on Jun 9, 2015 13:15:21 GMT
Failed unfortunately. Only a couple of things though:
Emissions, the lambda reading is too high. The other readings are fine though. I called Omex when I was at the test and they sent me a slightly altered map but the reading was still too high.
Rear brake force not high enough - it was 4% below the requirement. I think the balance bar may need adjusting for this.
The other thing was no manufacturer plate. I have not heard of anyone else mentioning this. The inspector showed me the requirement in the manual though.
Any ideas on the emissions problem?
Stew
Post by mawdo81 on Jun 9, 2015 14:28:57 GMT
Was it a new or donor engine?
Post by ssmith764 on Jun 9, 2015 15:15:32 GMT
It was a donor
Post by mawdo81 on Jun 9, 2015 17:21:45 GMT
Might just need a thorough service/clean up as per an mot failure then...
Post by ssmith764 on Jun 9, 2015 19:40:14 GMT
I think I have found the emissions problem after a bit of internet searching. It seems the lambda sensor senses oxygen and this can be caused by small leaks in the exhaust system. I did some checks using this clever idea - www.instructables.com/id/Find-an-exhaust-leak-without-burning-your-hands/And found a leak at the back of the exhaust back box and I think this must be the problem. It is not enough to be able to see anything blowing out of it but I can definitely hear it
Post by chizzy on Jun 9, 2015 19:42:02 GMT
If other readings ok then could be slight exhaust leak allowing air into exhaust system, known that many times on MOT's
Post by ssmith764 on Jun 16, 2015 11:01:32 GMT
I have sealed everywhere I can on the exhaust and I can not hear any leaks but the lambda is still too high as confirmed when I took it to a local garage. Everything I read though still says it would point to a leak. I am going to strip the whole lot now and put a new manifold gasket on and some sealant around the join between the cat and the manifold. Weirdly since I sealed the leak that I found the lambda reading from the garage was higher than the one on the IVA test.
Post by mawdo81 on Jun 16, 2015 11:48:24 GMT
Have you checked the O2 Sensor? If that is faulty it would give the ECU the wrong information to feed the engine...same for the MAF.
Post by ssmith764 on Jun 16, 2015 13:13:10 GMT
I have not checked the sensor but it is new as I bought it with the ECU (Omex). Maybe I should ask them what I need to do to test it is working correctly. It is running without a MAF sensor.
