Post by ssmith764 on Nov 11, 2013 19:14:28 GMT
I have now got the correct banjo's and bolts fitted which is much better
Post by ssmith764 on Nov 11, 2013 19:16:44 GMT
I have moved on to fitting the cycle wings now but have a problem because I bought 215 section tyres so they do not fit under the wings with the wing stays in their standard position. I thought I could cut off the stay bars and make some 'sleeves' to go over them to make the wings both adjustable and removable. I made a massive schoolboy error though of cutting the stay below the bracing bar so I had to fix that first with some more sleeves.
Post by ssmith764 on Nov 11, 2013 19:17:34 GMT
Now I have it glued on it looks ok and is solid
Post by ssmith764 on Nov 11, 2013 19:21:38 GMT
I am pretty sure the wing is in the right position for IVA as it has to cover the front line of the wheel rim which it does. I think these wings would be really hard to fit though even if you had the right size tyres
Post by airforceone on Nov 11, 2013 19:28:49 GMT
Is that double banjo's on the brake cylinder's?.
Post by ssmith764 on Nov 11, 2013 19:30:28 GMT
Yes - double banjos - not a problem I hope!
Post by airforceone on Nov 11, 2013 19:31:32 GMT
Just wondered why, are you not using t-pieces at the front or rear.
Post by ssmith764 on Nov 11, 2013 19:39:49 GMT
I had the lines made up at the local motorcycle store and he suggested using the double banjo as he said that modern motorcycles use this system. The cost of all the lines and banjo parts were a lot cheaper than the rtr kit too.
Post by airforceone on Nov 11, 2013 19:44:10 GMT
Just curious. Never seen it done like that before. If it works and has saved you cash then it's all good. You can use that saved cash for another upgrade later in the build.
Post by ssmith764 on Jan 8, 2014 22:04:30 GMT
Post by Paul (madeye) on Jan 9, 2014 7:58:13 GMT
ive been having a slow progress time lately but trying to get back on track, good to see your getting back on mate..
Post by ssmith764 on Mar 24, 2014 21:14:26 GMT
Post by Deleted on Mar 24, 2014 22:29:49 GMT
Looking good You do have drain holes under the tank don't you???
Post by ssmith764 on Apr 26, 2014 21:25:40 GMT
I have been looking at getting the camber and toe set up today and have noticed differences on either side of the car. To get the camber correct I have had to adjust the top ball joints as shown below. Has anyone else found similar differences? I have not set the toe yet but it looks like I will need to do similar with the track rod ends and have one side significantly different to the other
Post by ssmith764 on Jul 2, 2014 20:30:45 GMT
A few updates on the build - Fuel tank cover finished Made a centre console for the switches Steering boss and new steering wheel Fitting crush tubes for the seat runners
