Post by erik on Apr 14, 2013 21:03:38 GMT
If you look at any of the build threads we have had to cut and weld to connect the rack pinion clamp to the column uj. It would better I think if this part was pre made and came with the kit as its a part that needs welding and not just drilling and bolting. I didn't weld mine, placed the steering column bracket centre to thr seats. Had to shorten the shaft approx 0.5" Have a browse in my thread. good progress!
Post by andy7b on Apr 18, 2013 13:38:25 GMT
Thanks for confirming I'm not being a plonker on the seat position Kevin, I fart arsed around for ages trying to get a position Im happy with. I agree about the column joint maybe being part of the kit too but I'm happy to make something up. And thanks for the compliments the light units did take a bit of time but hopefully will be well worth it:-)
Post by Deleted on Apr 22, 2013 9:55:29 GMT
I bought a purpose made shaft from CBS and cut it and welded it, it has splines on either end, so once you know the distance, you can make a nice job of it. Think it cost £30
Post by slugshot on Apr 22, 2013 12:05:53 GMT
haha that would be far too easy he will probably make a link out of a chunk of ally or formed one in carbon
Post by andy7b on Apr 22, 2013 20:52:48 GMT
I don't know what your talking about Kevin ? Is it just me or has this forum changed format completely ? ? It seems much harder to use now
Post by slugshot on Apr 22, 2013 21:27:09 GMT
I don't know what your talking about Kevin ? Is it just me or has this forum changed format completely ? ? It seems much harder to use now Looking at your build so far and the lovely crafted one off fittings I can't imagine you will buy a cheap steering UJ from CBS as nick and myself have although it won't be seen so does it really matter. I agree regarding the new look forum, I had no complaints with the old look.
Post by Deleted on Apr 22, 2013 22:49:33 GMT
To be honest, the steering column link was a nice bit of kit, and mine looks very good now it's been Tig welded. It does the job it's meant to do, no point in recreating something that's lighter that might fail, when you have a purpose made item off the shelf. The build is hard enough without having to rethink everything.
Post by andy7b on Apr 23, 2013 18:52:41 GMT
I'm not that bad Kevin, but I do like to do things as nice as I know how:-) the CBS stuff looks just die and will make life a bit easier, but don't worry there are plenty of other areas where I can go a bit mad:-)
Post by andy7b on Apr 23, 2013 18:54:49 GMT
I meant to say fine not die, and I would edit the post but I can't for some reason,
Post by erik on Apr 23, 2013 19:27:31 GMT
use edit option top right post
Post by andy7b on May 6, 2013 20:52:18 GMT
I may have missed Stoneleigh this weekend but I have bought the steering joint with bar and spline from CBS and it will do the job just spot on, also I've got the front end built up this weekend and cycle wings trimmed and ready for me to bond them to the brackets at work this week. The drivers seat is all fitted now and I think it's as low as I can get it, and after the MSVA I will most certainly be changing the wheel for a smaller one and adding about 6" to the length of the column I've had a couple of bits painted and fitted the fuel pump and I plan to put a panel over the top to go from air box down to the frame. So I'm getting there slowly hopefully get the MSVA sorted in August.
Post by erik on May 6, 2013 21:01:10 GMT
resembles pretty much like a flintstone mobile now LOL!! relocation the steering column bracket worked like a charm for me
Post by erik on May 6, 2013 21:03:04 GMT
I have been eyeballing to those ultralegras as well. Have you weighted them?
br! Erik
Post by andy7b on May 6, 2013 21:05:56 GMT
They weigh in at 6.5kg so about as light as I could get and still be road legal, they do them in magnesium too but that's just being silly :-)
Post by erik on May 7, 2013 15:30:51 GMT
Nice weight of that 16"wheel.
