Post by andy7b on Feb 6, 2013 21:56:14 GMT
So having said hi I guess I best start doing some work, my kit arrives in a couple of weeks hopefully and I've been merrily stripping an R1. Its a 2000 so carb model to keep life nice and simple. A few bits have sold but still got stuff to shift to make space, most of the rear end is now serviced and ready to go, new bearings, anodised/painted and re-sealed. I would like to put pictures up but could someone tell me how to do it on an iPhone please cos I can't work it out 😣 I'm much safer with nuts and bolts than technology..........
Post by edwinwl on Feb 7, 2013 12:19:27 GMT
Hi Andy, First: Foto's are uploaded to a picture hosting site, like photobucket. ( www.ebizmba.com/articles/image-hosting-websites ) Second: On this forum only links are placed to the actual picture on the web. There are threads on this forum exactly explaining how to do it.
Post by edwinwl on Feb 7, 2013 16:44:23 GMT
Oh yes....
We are looking forward to your build pictures!
olberj
SC Rocketeer
Post by olberj on Feb 7, 2013 17:31:53 GMT
Andy7b, PistonHeads regular?
Post by andy7b on Feb 7, 2013 22:20:10 GMT
Right think I've got the pictures working. This is the R1 I started with.
Post by slugshot on Feb 7, 2013 22:27:15 GMT
Congratulations
You have now completed the most difficult Part of building the tR1ke.
(POSTING A PICTURE) ;D
Post by andy7b on Feb 7, 2013 22:32:20 GMT
damn right and I had to get the wife to do it, and so far we can only manage 1 as for some reason it now just says that I've moved the poxy picture😏
Post by erik on Feb 8, 2013 7:22:02 GMT
Wow. That fairing looks really sweet! During the dissasembly I made pics , put the parts in bags and made adds every day which made the process less fuzzy. Your wife did a great job. Great to share a hobby! br, Erik
Post by andy7b on Feb 8, 2013 20:04:17 GMT
So a bit more practice at the photo thing and all is now well👍 as well as getting the wife involved I've now completed the family when my daughter decided that the rear wheel makes a great toy. And in reply to am I on pistonheads lots the answer is nope not me, this is the first forum I have used and I'm learning every time I use it 😃
Post by andy7b on Feb 13, 2013 12:43:58 GMT
so front wheels, im going for 16x7,s but what offset have people been going for ET30 ish ??
thanks andy
Post by slugshot on Feb 13, 2013 16:27:19 GMT
Mine have 35mm offset + a spacer to bring it upto 38mm
Post by edwinwl on Feb 13, 2013 18:52:37 GMT
ET35 to ET45
(It's Ford Focus, mark I )
Post by andy7b on Feb 13, 2013 20:39:46 GMT
Thanks, If you put a 3mm spacer on top of a 35mm won't that make them an ET32? As the spacer takes the hub face closer to the centre line of the rim? Or am I back to front😳
Post by slugshot on Feb 13, 2013 21:30:30 GMT
Thanks, If you put a 3mm spacer on top of a 35mm won't that make them an ET32? As the spacer takes the hub face closer to the centre line of the rim? Or am I back to front😳 Sorry Andy...ignore my last measurements Ive just checked my wheels and they have an ET of 40mm +A 5MM spacer so as you rightly said it would be a total ET of 35mm My wheels are 15in rota slipstream and the wheel nuts only have a small amount of thread showing through the wheel which has always bothered me so I ideally want longer studs. I don't know if its the same for other wheels though. Cheers Kevin
Post by andy7b on Feb 13, 2013 21:43:24 GMT
No worries, I wasn't sure myself but thought I'd ask, I guess as long as there is 1x diameter of thread in the nut then It should be fine and I would think you would have found out by now if there was a problem😁 I plan to go for 16's as I like the bigger wheel but would also like some tyre side wall to help things out a bit 👍
