Post by huggy on Jun 11, 2014 20:23:06 GMT
Another random job in between other tasks: Front of center console made.
Post by huggy on Jun 11, 2014 20:47:18 GMT
Getting on with the wiring
Post by huggy on Jun 11, 2014 20:51:45 GMT
Made a bracket to hold ECU ECU mounted on rear bulkhead
Post by huggy on Sept 11, 2014 21:38:54 GMT
More wiring: Wires from lighting and indicator stalks ready for connection RTR loom ready for connection This is slow going! Pretty much done. Just need to cable tie, secure and tidy up a little.
Post by huggy on Sept 11, 2014 21:44:49 GMT
Bought the Koso RX2N+ speedo, so time to reverse the fuel gauge sender by bending the float arm. Could have bought / made a circuit to do the matching, however simply decided on the brute force (and what I think will be one 270 ohm resistor in parallel) solution instead: ...before ...after.
Post by huggy on Sept 11, 2014 21:51:34 GMT
Oil and water temp sensors for the Koso dash fitted: Removed plug to the left of the oil pressure sender. Oil temp sensor fitted. Water temp sensor adapter fitted to cooling pipe and sensor fitted.
Post by shaggy33 on Sept 13, 2014 21:37:33 GMT
Looking good huggy. I had a day on the electrics today with my guru, will post some pics tomorrow. I tried to remove the blanking plug so I could fit my koso oil temp sensor like you have but managed to expletive deleted up the bolt and now I can't undo it! Gutted as I wanted an oil temp reading. I daren't dremel any more slots in the bolt (in and effort to get a flat bladed impact driver into the head) for fear of the head collapsing. Made a right hash of it, gutted. Anyways looking good mate
Post by huggy on Sept 13, 2014 23:29:39 GMT
Looking good huggy. I had a day on the electrics today with my guru, will post some pics tomorrow. I tried to remove the blanking plug so I could fit my koso oil temp sensor like you have but managed to f**k up the bolt and now I can't undo it! Gutted as I wanted an oil temp reading. I daren't dremel any more slots in the bolt (in and effort to get a flat bladed impact driver into the head) for fear of the head collapsing. Made a right hash of it, gutted. Anyways looking good mate Cheers. Re. your plug, if you know any engineers, get them to take a look. My cousin was able to work wonders with snapped bolts, rounded heads etc... when I was rebuilding a 1972 VW engine back in the past. Hopefully we will both be on the road soon, i.e. in time to make the most of next summer!
Post by jamsterjay on Sept 14, 2014 7:26:43 GMT
My blank in the block also f-ed up so i bought a set of laser easy outs, open the hole out to a snug fit and it worked a treat.
Post by kiwicanfly on Sept 14, 2014 8:35:52 GMT
My blank in the block also f-ed up so i bought a set of laser easy outs, open the hole out to a snug fit and it worked a treat. What's a "laser easy out"? Sounds like some type of sci-fi death ray
Post by shaggy33 on Sept 14, 2014 9:24:37 GMT
Post by mawdo81 on Sept 14, 2014 10:38:16 GMT
How do you use them?
Look around for Laser and equivalents. I've found halfords horribly overpriced and only use if I'm willing to pay the premium to have it in my hand straight away.
Post by kiwicanfly on Sept 14, 2014 10:55:38 GMT
They are stud extractors.
You drill a hole in the centre of the broken bolt then you screw the extractor in, the trick is the fact that the extractor is left hand thread so as it tightens in it undoes the broken bolt.
Post by shaggy33 on Sept 14, 2014 10:58:42 GMT
I agree, I despise halfords or as I call them halfrauds:-)
Post by deanohonda on Sept 14, 2014 11:23:12 GMT
This all sounds like 2 much hard work :-) if u check ur koso paperwork there are modifyed sump bungs avalible where the sensor srews into the sump bung & with it that way you are picking up the oil temp & possible not picking up any surrounding block temp
