Post by mawdo81 on Sept 14, 2014 12:42:37 GMT
Thanks Kiwi
Post by huggy on Dec 11, 2014 23:15:44 GMT
More random jobs: Another bracket before after
Post by huggy on Dec 11, 2014 23:17:57 GMT
... and more wires: (that's really it this time...... I hope). Will tidy up, cable tie, secure etc... once fully tested.
Post by huggy on Dec 11, 2014 23:20:15 GMT
... and another bracket made that will eventually secure the speed sensor. (yep... not particularly exciting)
Post by huggy on Dec 11, 2014 23:26:31 GMT
More center console work Planned layout vs. cutouts Sides made and test fitted Ready to be dismantled and trimmed.
Post by BobN on Dec 12, 2014 8:13:57 GMT
Looking good.
Bob
Post by huggy on Apr 2, 2015 21:58:05 GMT
Slow progress recently (...baby 2 arrived:)). Here are the updates: Active speed sensor fitted Glued bolt heads to drive shaft (...using slow setting epoxy) Went for four points equally spaced (i.e. 90 degrees) around the shaft
Post by huggy on Apr 2, 2015 21:59:50 GMT
Added gearbox fluid
Post by huggy on Apr 2, 2015 22:04:24 GMT
Rear fog and reverse light fitted: Basic extensions for indicator/tail/brake light units to meet IVA 100mm requirement Indicator/tail/brake units fitted
Post by mr9802 on Apr 3, 2015 3:49:25 GMT
Slow progress recently (...baby 2 arrived:)). Here are the updates: Active speed sensor fitted Glued bolt heads to drive shaft (...using slow setting epoxy) Went for four points equally spaced (i.e. 90 degrees) around the shaft Congrats! My second was born just about 3 weeks ago. Digging the build!
Post by Stiggy on Apr 3, 2015 8:59:27 GMT
Hi, love the dash and sensor bracket, I am concerned with heat from the exhaust here, I had a sensor fail when mounting here, just a thought. Glad to see you enjoying your build.
Post by huggy on Apr 3, 2015 19:56:34 GMT
Hi, love the dash and sensor bracket, I am concerned with heat from the exhaust here, I had a sensor fail when mounting here, just a thought. Glad to see you enjoying your build. Thanks for the heads up. Will look to add some sort of heat shielding around sensor next time I get out.
Post by huggy on Apr 16, 2015 22:00:26 GMT
Stub extensions to raise headlights: Dominator headlights fitted. Note: front indicators mounted on headlights.
Post by huggy on Apr 16, 2015 22:08:25 GMT
Wiring tested and working, so initial tidy up done (i.e. junction blocks, fuse & relay holder fixed in position, and wires cable tied):
Post by carlyd on Apr 17, 2015 11:37:04 GMT
I'm just buying my wiring stuff, what what are the relays I need to buy please?
