Post by huggy on May 17, 2014 0:05:35 GMT
Rear bulkhead fitted. Can also see conduit added to the engine loom. Holes drilled and grommets added for fuel lines
Post by huggy on May 17, 2014 0:07:08 GMT
Fuel pipes fitted. Fuel rail end. Bulkhead end
Post by huggy on May 17, 2014 0:11:05 GMT
Back to the electrics: Bracket for tray to mount fuses and relays on ...more brackets ...and the tray
Post by Deleted on May 17, 2014 7:05:44 GMT
I assume your going to grommet the fuel pipe holes you drilled??
Post by huggy on May 17, 2014 9:15:48 GMT
I assume your going to grommet the fuel pipe holes you drilled?? Yep, done. You can see them on the cabin side of the bulkhead. The heat shield, mat obscures the view of them on the engine side.
Post by Deleted on May 17, 2014 9:18:32 GMT
Lol.. You know I have to ask.. sometimes we miss the obvious... Looking good buddy.. when are you aiming for IVA??
Post by huggy on May 17, 2014 9:30:35 GMT
I really appreciate the safety checks, especially as this is not my profession. Thank you. Well, I was aiming for last November. Oops, missed that date in a big way It feels like I should be able to finish within months given an hour or two after work and some long weekends. I think my 1 year old has other plans though
Post by huggy on May 23, 2014 21:07:06 GMT
Catch can plumbed in:
Post by drbrian on May 27, 2014 21:29:18 GMT
Why exactly did you need to put the thermostat here? Do I need to do something similar? Should I also block of my the other side of the housing like you did? Thanks Brian Another small job: Thermostat housing removed and drilled (13mm) Ford coolant temp sensor Sensor fitted
Post by huggy on May 29, 2014 3:19:19 GMT
Why exactly did you need to put the thermostat here? Do I need to do something similar? Should I also block of my the other side of the housing like you did? Thanks Brian Another small job: Thermostat housing removed and drilled (13mm) Ford coolant temp sensor Sensor fitted Bought the omex 600 ecu and this is what they recommended re. the thermostat feeding the ecu (as per their turn key engines). If a direct feed to the dash, people have done other things too, like a tee in the cooling pipe (e.g bob's build if I remember correctly). Re. blanking the othe pipe, this seems to be the most common solution. There is a thread on the cooling setup in the tech section. There are basically a couple of recommended solutions depending on your specific setup.
Post by drbrian on May 29, 2014 3:56:27 GMT
Post by airforceone on May 29, 2014 16:46:03 GMT
That probably is a good position for the coolant sensor,BUT , by the time you've put the thermostat housing back on and connected the hoses then filled with coolant, it is not a very good place to discover a slow leak.
Can you even get to it when the bulkheads are on and wiring and hoses are fitted.
I've just had a look at mine and I struggle to even see that fitting.
Post by kiwicanfly on May 29, 2014 19:10:22 GMT
I agree with Ned, I cannot even get a good photo of mine.
Also mine does have a slow leak !
Not enough drama to be bothered moving it but I think a position of easy access would be a good choice.
Post by airforceone on May 29, 2014 19:42:54 GMT
If you have a slow leak now, when the car/engine is running and the coolant gets up to temp then the slow leak becomes something more.
A slow leak at my radiator is what pushed me to change it. I noticed a small puddle of coolant under the rad, my expansion bottle level was always dropping and I had to bleed the system on a regular basis, never mind the constant checking of coolant levels on anything other than a short journey.
It takes away the enjoyment of a drive-out of you always have one eye on the temp.
Don't mean to sound all doom and gloom but this is all from experience, I won't bother telling how much grief I had with re-fitting the thermostat housing after fitting my coolant sensor, leaked for weeks. A right PITA.
Post by huggy on May 29, 2014 21:10:37 GMT
Noted and will keep an eye on it.
