Post by erik on Jun 12, 2014 16:03:40 GMT
15/49 makes the highest ratio this far on a tR1ke on this forum. Other recommended ratios are 15/46-47 and they seem to like it. I'm looking forward to your experiences. i haven't decided to change my ratio for now because the chain and sprockets are in too good conditiion and I cannot make up my mind...
br! Erik
Post by paulh on Jun 12, 2014 16:15:42 GMT
I think Kevin was running 14/50 at the Llandow track day, but he has more patience than me and doesnt mind swapping sprockets between road and track
Post by slugshot on Jun 12, 2014 16:31:20 GMT
15/49 makes the highest ratio this far on a tR1ke on this forum. Other recommended ratios are 15/46-47 and they seem to like it. br! Erik The internal gear ratio's in Pauls motor are totally different to our earlier xv,jj,5pw motors. Also it would have been the lowest ratio not the highest
Post by slugshot on Jun 12, 2014 16:44:42 GMT
After speaking to Kev last night, I have now got a new set of sprockets to fit and gear the tR1ke down a bit. with the 16/46 set my theoretical top speed was 175mph. this will now be changed to 15/49 bringing speed in top down to 154mph, and only 77mph in first.I hope this will allow me to use more than just first gear around Curborough. I can smell tyre smoke just thinking about it
Post by paulh on Jun 12, 2014 20:19:20 GMT
Not much tyre left Kev All I can smell now is beer!
Post by paulh on Jun 12, 2014 20:20:28 GMT
I also found 3 spare links of chain in the garage, so I must have only used 3 extra originally
Post by slugshot on Jun 12, 2014 20:24:56 GMT
Thats good then, don't forget your speedo will be over reading with the lower gearing.
Post by paulh on Jun 12, 2014 22:59:41 GMT
yeah, will have to set the speedo healer up again
Post by paulh on Jun 14, 2014 19:40:00 GMT
New sprockets fitted and test drive done! I haven't yet set the speedo healer or gear indicator, but the difference is massive. Pulling away is much better not sure about any difference in acceleration, but can go all the way to 6th gear with the back wheel spinning. Probably time to fit the new rear tyre now!
Post by edwinwl on Jun 14, 2014 21:21:42 GMT
My personal record is a powerspin @ 115km/h.....
Post by slugshot on Jun 14, 2014 22:26:11 GMT
Pulling away is much better not sure about any difference in acceleration, but can go all the way to 6th gear with the back wheel spinning. Lowering the gearing helps pulling away but you will have to get a trackday tyre if you want better grip, either that or try pulling away WITHOUT full throttle, I know you've never tried this technique but it might help
Post by paulh on Jun 15, 2014 1:31:14 GMT
Kev. No full throttle I don't understand ? What is this?
Post by erik on Jun 15, 2014 10:40:13 GMT
throttle management
Post by paulh on Oct 20, 2014 21:56:25 GMT
My Tr1ke is up for sale as of today. I bought Matts unfinished Mevabusa Kit the weekend so the tR1ke needs to go to finance the new build
Post by Deleted on Oct 20, 2014 22:55:44 GMT
Good luck. Hope you get a good price
