Post by wonderbadger on Sept 17, 2014 8:26:03 GMT
Glad you're ok and hope the tR1ke isn't too badly damaged. On the subject of visibility, on my previous Striker I used a motorsport rainlight as a high level brake light. It would rely on keeping your foot on the brake in standing traffic which I'm not a fan of but was brilliantly bright, if they can't see that then they're not going to see anything.
Post by airforceone on Sept 17, 2014 12:05:59 GMT
You could also fit a switch to the accelerator pedal so that when you are stationary (foot off the pedal) the light is on saving you the hasstle of pressing the brake.
Post by wonderbadger on Sept 17, 2014 18:40:49 GMT
Taking that switch idea one stage further (maybe a stage too far but my braincell went off wandering by itself!) but, wonder how easy it would be to make a circuit which measured distance to the vehicle behind when stationary, when something comes within X-meters, the brake lights/high intensity rain light comes on for X-seconds. Another thing I was looking at previously when I had the bike was meant for front high intensity DRLs and made them twinkle as they are then more visible than a static light source - wonder if that would catch attention to the rear (albeit both ideas are of dubious legality)
vtR1k
I'm a trike lover...
Post by vtR1k on Sept 17, 2014 19:59:09 GMT
Both ideas sounds good and not too difficult to carry out. And about the legality: I think when it can prevent a collision, it will be worth a ticket... (FYI: due too stupid dutch regulations, my trike has also illegal safety belts. Since the legal ones are IMO unsafe, I fitted these. I am confident that these belts prevented furher physical damage, so f*** the rules).
I know that in the past, modules could be bought to make the brakelight flash when making a emergency stop. This is also a possibility...
Sent from my S4 Active.
Post by kiwicanfly on Sept 17, 2014 20:01:18 GMT
What are the differences in the seat belts ?
vtR1k
Post by vtR1k on Sept 18, 2014 4:43:32 GMT
Dutch regulations say that you need to unlock the belts by pressing a button, like all factory cars have. All the decent belts that are available have racing car type turn knob release systems. The street legal belts look a bit el cheapo, the straps are narrow, and they are much more expensive. They also aren't available as a 6-point design (which I really wanted for safety).
About the visibility: I also fitted 3 rear lights, also illegal here in NL, but no police officer has attended me to this yet. If they do, I can explain why I did that. They are sensitive for safety based modifications I think.
Post by kiwicanfly on Sept 19, 2014 8:16:49 GMT
I followed, what looked like, a new model MX5 today. On braking the high brake light flashed, it did about 5 flashes in maybe 2 seconds then was steady for about 3 seconds, then repeated this until the car moved on.
I checked when it was stationary, it was definitely programmed in and not a loose connection.
Timing isn't important just the fact it did this made it more noticeable.
As it was a production car it must be legal.
Post by busaash on Sept 22, 2014 16:42:35 GMT
Really nicebuild thread , I am reading before I buy doing as much as I can
Post by erik on Sept 23, 2014 16:19:52 GMT
Hi Rik,
I missed your accident report. That sux big time. I hope you find the fun of repairing. I guess you will dissassemble the chasis for a recoat?
best wishes, Erik
vtR1k
Post by vtR1k on Sept 25, 2014 18:57:04 GMT
Don't know yet. Miraculously the frame is only damaged at the underside of the vertical frame parts at the rear, where it came in contact with the tarmac.... and this I can solve with paint. I can't find any other damage to the frame at all. Almost all the R1 parts (wheel, swingarm, exhaust etc) are destroyed... Even the fuel pump and air filter housing didn't survive. But engine, throttle bodies and frame seem to be ok. Nosecone is also cracked at the front.
Post by Peregrine on Jan 6, 2015 11:54:00 GMT
Hi Rik,
Any update on how the rebuild is going over the winter?
vtR1k
Post by vtR1k on Jan 13, 2015 11:08:42 GMT
Hi, well I received the insurance payment this friday, so I can start to order all the replacement parts now...
vtR1k
Post by vtR1k on Jun 3, 2015 19:44:23 GMT
So far so good! First 2000 miles are driven after the winter rebuilt. What I repaired and modified: Renewed complete rear section: wheel, swingarm, new brake disc & pads. Mounted a hyperpro racing shock with extra heavy spring and Akrapovic mufflers with cat replacement tube. Fitted a scottoiler so I don't have to spray the drive chain every 300 miles anymore. Since the original handbrake didn't wowrk at all, I mounted a hydraulic hand brake and removed the old one. I already mounted a power commander, but now I added a autotune module (with a wide band sensor) so the mixture stays correct. It has 2 settings, 1 for optimum AFR ratio for cruising mode and the other is for extra performance, which can be programmed myself. With the extra display I ordered I can read out the motormanagement data during driving. I also bought a Waeco cruise control, this is really convenient on the highway! For better handling I also mounted a front anti roll bar, what a difference this makes! Unbelievable! Concerning extra visibility I replaced the tail lights for the ones with integrated indicators and the 3rd brake light starts blinking when I brake. This is a extra (illegal) module made by Heal Tech. Illegal, but an extra warning signal doesn't do any harm, I think. Last but not least: some nice striping. So far for the update! Sent from my SM-G925F using proboards
suliko696
Newbie
Hi, My name is Sergei, I'm from Dortmund, I am a model builder, form builder by profession .
Post by suliko696 on Jul 5, 2016 12:04:27 GMT
Hi, My name is Sergei, I'm from Dortmund, I am a model builder, form builder by profession ..
I have a lot of fun which rehearse, new to machen.Ich would like Tr1ke MEV buy, build in himself a new out.
That because I want to ask you: can before I come in and watch your Tr1ke, perhaps make a test drive with you ?! Just put this experience to have ..
Do you speak a little German?
I would be very grateful for an answer!
Greeting
Post by erik on Jul 5, 2016 16:50:46 GMT
Hallo Sergei, Es gibt noch eine tR1ke zum verkauf in die Niederlande: www.kitcarcollection.com/kitcarsite/page_voorraad_trikesEine neue tRike oder 4wd bauen mit Englischen "tüv" ist eine risico (Brexit= Brittischen prüfing nicht mehr EU legal und warscheinlich nicht strassenlegal zu machen ausser UK).Auch neue schwerere prufungen am motor (euro6) wirdt ne neue kitcar warscheinlich eine zu grosse aufgabe. Motorrad moroten sind uberhaupt nicht in euro6 erhältlig deshalb baut EML keine trikes mehr fur EU nur USA und Japan. Lass ihn bei eine deutsche kitcar vertreter/forum mal richtig informieren. hier nog eine informative draht: mevowners.proboards.com/thread/8074/supporting-borismfg, Erik
