vtR1k
I'm a trike lover...
Post by vtR1k on Dec 9, 2012 16:14:03 GMT
Here are some pictures of the beam (main and dip). I still need to adjust them by the way, and the right is brighter than the left, so I want to claim one bulb for warranty: I also made a carbon cover to protect the bottom side of the radiator: That is all for now. Next weekeind I will be playing with it on the racetrack of Zandvoort (if the wetter is cooperating a little...) Hopefully I can shoot a nice video!
Post by slugshot on Dec 9, 2012 16:58:16 GMT
Thanks for the pics they are a nice white beam, the normal bulbs aren't bad but still a good improvement. Cheers Kevin
vtR1k
Post by vtR1k on May 26, 2013 7:17:49 GMT
A very short video, shot 2 weeks ago in Luxemburg, with showing the reverse gear. Sent from my HTC EVO 3D X515m using proboards
vtR1k
Post by vtR1k on Jan 19, 2014 10:06:49 GMT
Since I have no problems of any kind with my tR1ke, it is time to make some luxury modification. I want to fit a cruise control system, Waeco magic speed MS700. Has anyone experience with it?
Sent from my mobile phone
Post by edwinwl on Jan 19, 2014 12:25:54 GMT
vtR1k
Post by vtR1k on Jan 19, 2014 20:33:57 GMT
Yes, I did some rechearch already. I need type 700 because it doesn't need a vacuum resource. Since it is not particulary cheap, before I order it, I would like to know how weather resistant it is. Also, the controls are mainly intended to mount inside a car, I am afraid that a drop of rain will ruin the buttons. So, if anyone knows about it, please feel free to share your knowledge . Sent from my mobile phone
vtR1k
Post by vtR1k on May 24, 2014 17:18:24 GMT
I was getting a little tired of removing the complete nosecone every time I had to check brake fluid, coolant, adjust clutch- and throttle cable, etc etc. So, I made me a bonnet! Afterwards, I let all the orange bodywork wrap with orange Avery wrap foil, to avoid an expensive paint job... Sent from my S4 Active.
Post by edwinwl on May 26, 2014 11:45:33 GMT
Great!
How do you make the fixing?
Post by andy7b on May 26, 2014 19:10:24 GMT
That is a good idea and looks really nicely done too :-)
vtR1k
Post by vtR1k on Jun 2, 2014 16:57:41 GMT
It is fixed with 5 M5 countersunk bolts and rivet nuts. And carbon and epoxy resin for the edge where the bonnet lays on...
I don't know how to explain it with text, so I will try to make an explanation later...
Post by erik on Jun 2, 2014 20:04:45 GMT
Hi Rik, epoxy resin is a poor adhesive on polyesther. You should reconsider an additional overlap of cloth and polyesther over the carbon cloth. Make sure you grind/sand off the surface of the epoxy resin, preferable as rough as possible. Degrease with acethone or thinner and let the molecules vapourise for 24hrs or it might affect adhesive performance of the resins. Great modification tough! br, Erik
vtR1k
Post by vtR1k on Jun 3, 2014 19:37:02 GMT
Thanks for the advice Eric, but it is a really stirdy fit... How long would it take to fall off normally? I spilled some drops, but I had to remove them with sandpaper afterwards... even on the smooth gel coated surface on the outside I couldn't peel the drops off, so I assumed the epoxy will hold...
Post by erik on Jun 4, 2014 15:20:56 GMT
The bond could take a long time to hold depending if the surface is stiff enough. If it shows flexit may come loose and quite often if it shows a small air gap in the seam it could fall off very easely. On the model aircraft planes (mostly made from polyesther resin to cut costs) there is no way to glue parts or formers in place with epoxy resin. The next best thing to do is tear off the epoxy resin from the poly surface and glue back with CA (cyano acrylat/seconden lijm) which etches the surface and gives a chemical good bond.
Please take proper care of the countersunk holes. The gelcoat and poly waeve is brittle and may show wear very soon. I do use stainless washers with silicons washers glued undrneath to extend the GRP lifespan. They should be available at the local hardware store.
br, Erik
Post by jelle on Jul 9, 2014 19:53:09 GMT
Hello vtR1k, stellar work I must say, congrats!
Could you share how you made the brake bias (verdeling) between front and rear? Is it adjustable or fixed like 70% front and 30% rear brake? Really interested in that.
Cheers,
Jelle
vtR1k
Post by vtR1k on Jul 10, 2014 16:44:42 GMT
Hi Jelle,
It is a standard turn- knob, but it is crappy. It works with a cable, basically the same as the old speedometer cables. But the balance bar turns too heavy so the cable keeps loosening... Frankly, I have no idea how the setting is at the moment...
