Post by einy on Sept 13, 2015 22:50:41 GMT
Interesting ... The tank from my 1991 sits way low in front, ~4" higher in rear, yet clears just fine. Would have thought your 1994 tank would be the same design ??
Post by BTD on Sept 16, 2015 4:26:14 GMT
Now I'm really confused...mine is so much higher than both of yours in the front and it's still nearly contacting the subframe. No heatshield underneath. Is my diff unusually high or something??? Pics for reference: Top orientation: Driver's side w/ mount heights: Passenger side view: Rear View: Closeup:
Post by einy on Sept 16, 2015 11:20:51 GMT
PM'd you regarding fuel tank / rear cover fitment.
Post by lhintze on Sept 16, 2015 12:14:43 GMT
Just looking at the pics quickly, I think you will have to lower your tank once your trunk arrives. Mine was about that height and I lowered it 2" to make the trunk fit.
Post by BTD on Sept 16, 2015 15:45:11 GMT
Just looking at the pics quickly, I think you will have to lower your tank once your trunk arrives. Mine was about that height and I lowered it 2" to make the trunk fit. That's my problem...I don't think I have 2" to lower it. Guess I'll play around with it more tonight!
Post by greg on Sept 16, 2015 16:01:41 GMT
The NA tank is quite a bit taller than the NB one.
Post by BTD on Jan 13, 2016 6:04:10 GMT
Long time without an update. I have been busy purchasing a house (with a bigger garage!), so the work on the Exocet has slowed by quite a bit. Today, I got fuel lines in. Pedals are also 95% mounted, I just need to drill the spacer hole in the firewall. Tomorrow the car goes to Coyote Motors in Boulder to get the wiring put in and pared down. They're doing it for a great price and I've heard very good things about the shop. Hopefully we will hear her fire up before the weekend! I did my fuel lines placed on top of each other run along the passenger tunnel. P-Clips every 12" for each line, staggered so there's support every 6". Pics:
Post by BTD on Jan 15, 2016 5:25:25 GMT
Bye bye Exocet! I'll see you soon! AND IT WILL BE RUNNING.
Post by USStu on Jan 15, 2016 21:57:10 GMT
Where's she going?
Post by BTD on Jan 16, 2016 3:45:24 GMT
Coyote Motors in Boulder. They're doing all the wiring including pulling out all unused plugs/wires for what I think is a very, very reasonable price. I figured that given my lack of knowledge on wiring in general, it would be much more efficient to have them do it.
So, when I get it back I should have a car that will start, then all it will take is mounting the radiator, bodywork, and lights.
Post by gsrflyby on Jan 16, 2016 7:21:53 GMT
I wish there was somebody in Ohio that could do the same thing you're having Coyote Motors do, I wonder if I sent them a harness, if they could do the same job sans car.
Post by BTD on Jan 16, 2016 23:03:42 GMT
I can ask them when I pick mine up if you'd like!
Post by gsrflyby on Jan 17, 2016 6:25:05 GMT
That would be great, thanks!
