Post by mdizz7 on Feb 1, 2015 20:20:22 GMT
Where did you get your frame coated?
Post by BTD on Feb 2, 2015 4:56:42 GMT
Premier Powder Coating. Tony is the owner (well, him and his dog Jackson) and he's a great guy. (303) 282-4451, tell him Dan with the Exocet sent you.
Post by mdizz7 on Feb 2, 2015 5:38:19 GMT
Great thanks! I just ordered my frame a few weeks ago so it'll be a while before I get it Coated but good to know there's a good local option
Post by BTD on Feb 9, 2015 4:33:33 GMT
Engine bay is (nearly) empty! Today I got the rest of the wiring harness out, which involved accidentally clipping two wires with my sawzall. Whoops! body will be off this week, just need to disconnect fuel and parking brake and we should be all set.
Post by gl21133 on Feb 10, 2015 20:56:58 GMT
Dan, do you have any info on registering the Exocet in CO yet?
Post by ashneyder on Feb 10, 2015 20:59:11 GMT
You guys have the benefit of FM having a finished Exocet with plates on already.
Post by BTD on Feb 11, 2015 4:41:28 GMT
Dan, do you have any info on registering the Exocet in CO yet? Should be pretty simple from what I understand, you need a windshield and lights and such and then you just take it to the CSP office in Golden. I think you have to call to set an appointment and an officer will inspect the car, verify the VIN #'s aren't stolen (so keep proof of any major parts) and then you can apply for a CO assigned VIN. Kit cars are exempt from emissions in CO. This link is mostly up to date: Colorado Kit Car InformationWhen I went to the DMV office and asked for information on registering a kit car they gave me a stack of forms to fill out and went over the procedure. I suspect this varies by the individual you talk with at the DMV, so you may have to ask for a supervisor.
Post by BTD on Apr 1, 2015 4:32:08 GMT
Good and bad news today! First off, big thanks to Matt (mdizz7) who helped a ton with finishing up the disassembly of the donor. Always nice to have an extra set of hands. A few hours of work this last weekend, and the donor body is off! Off to the scrapper: Meaning my previously cluttered garage is now much, much more manageable: But now the bad news...while lifting the body off using an engine hoist, it slipped and landed squarely on the oil filler cap. It cracked the top of the cap, but when I removed it I found out that it actually cracked the cap all the way through, sending a large number of small pieces of plastic into my engine. I'll be taking the valve cover off anyway for the timing belt, but I'm just wondering what the best way of getting all these pieces out of the top of my engine is...any thoughts? Either way, on to the cleaning of my (mostly) rust free donor so that I can finally get the body and such mounted. My build may be slower progress than others, but it's progress all the same!
Post by einy on Apr 1, 2015 12:16:49 GMT
You should easily be able to find the remnants of the cap inside the head valley once you pull the valve cover off.
Post by greg on Apr 2, 2015 2:52:45 GMT
Worst case some chunks fell into the pan thru the drain holes.
Post by BTD on Apr 30, 2015 4:05:01 GMT
The mishaps continue. Looks like the previous owner hit the front subframe on something and bent a mounting point beyond fixing for the steering rack. Now I need a new front subframe. Treasure Coast is probably getting a call tomorrow...
Timing belt kit and shifter rebuild kits are in, rear subframe is going to the powdercoaters tomorrow. Hope to ahve the frame on in a week or two.
Post by BTD on May 29, 2015 6:06:22 GMT
Updates! Got the rear subframe back from the powder coaters today, looks great. Also got the rear diff bushings changed out. Big news though was that I (finally) finished my timing belt. My frist time doing it and I'm pretty sure it all went smoothly, but the true test will be starting it up. Engine didn't look terrible: Also rebuilt my shifter using a 5xRacing kit. All I have left to do is run the brake lines and paint a few misc parts. Frame and PPF should be mated this weekend!
Post by gwnwar on May 29, 2015 20:24:32 GMT
If you have 19 teeth between the top cam marks with all other marks on cam and crank in place.. front cam lobes pointing out to about 9 and 3 it should be OK
Post by BTD on May 31, 2015 0:36:10 GMT
Help! Put the rear subframe on today since the body will be going on tomorrow. When I installed the lower part of the bushing, I found that the bushing doesn't touch the diff arm, which I'm pretty sure that it should. Am I missing a washer between the subframe and the top bushing or
Post by BTD on Jun 1, 2015 4:29:33 GMT
Big day today, frame and PPF and finally together. It took loosening the PPF bolts and a bit of creative prying, but they're all in. Waiting on a few suspension bolts to come in before I can bolt the arms and such on, but it's nice to have things moving along!
