Post by jwagner on Dec 24, 2014 16:52:39 GMT
Useful info on this thread. I've got a '94 Miata that I'd like to share wheels with, so I'm inclined to use the spacers, even though I don't like the idea of them.
How heavy are the spacers? I'm a big believer in "lighter is better" and willing to pay more for RPF-1s + spacers, but if the spacer weights a couple of pounds there's probably no point and I should just buy the zero offset Holeshots.
JID - looks like you've got a lot more clearance than you need - is that to fit the fenders?
Do both the front and rear wheels need to be spaced/low offset? I assume if the front do, it's to fit the fenders.
Post by gwnwar on Dec 24, 2014 17:16:45 GMT
The weight of the spacer should not be that big a problem.. It is at the hub/center of the wheel weight you are turning. Multi tasking wheels good idea..
Post by gl21133 on Dec 24, 2014 21:00:14 GMT
FWIW I asked an eBay seller and he estimated the 38mm spacers are 4 lbs each.
Post by JIDiesel on Dec 25, 2014 0:18:09 GMT
FWIW I asked an eBay seller and he estimated the 38mm spacers are 4 lbs each. Estimated wheel load added by using spacers this size is less than 1 lb to the total rotational mass. Remember the weight on the outer edge of the rotational mass matters more than central mass.
Post by JIDiesel on Dec 25, 2014 0:18:30 GMT
Post by ImprobableConstruct on Dec 25, 2014 4:06:05 GMT
You do still have unsprung weight to consider though.
Post by gl21133 on Jan 31, 2015 2:49:23 GMT
Revisiting this, the more I think the more I don't want spacers. The options I see right now for 15x8 4x100 et0 wheels: -Traklite Holeshot or Drum -Rota Grid-V, Shakotan, Kyusya, RKR, or Zero Plus -A bunch of STR, XXR, Varrstoen, and other reps I'm not sure I trust -Volk TE37L (>$500/wheel) -Work Meister CR01 (>$500/wheel)
Am I missing anything? I feel like no option is quite what I want.
Post by BTD on Jan 31, 2015 3:46:55 GMT
Revisiting this, the more I think the more I don't want spacers. The options I see right now for 15x8 4x100 et0 wheels: -Traklite Holeshot or Drum -Rota Grid-V, Shakotan, Kyusya, RKR, or Zero Plus -A bunch of STR, XXR, Varrstoen, and other reps I'm not sure I trust -Volk TE37L (>$500/wheel) -Work Meister CR01 (>$500/wheel) Am I missing anything? I feel like no option is quite what I want. There's a bunch more offbrands that are 15x8 +0. Personally, I find XXR to be similar to Rota, ie acceptable quality. Perhaps a group buy is in order? I'm sure we can find a vendor willing to do a run if we get 5-10 sets. I'm happy to organize it if there's interest and the wheel is silver. 15x8 +0 or 15x9 -15 would be ideal.
Post by jwagner on Jan 31, 2015 4:57:04 GMT
Post by einy on Jan 31, 2015 10:45:57 GMT
That is a nice wheel, but from what I see it is a 25mm offset. I don't see a 0 offset available. regarding possible group buy if a 0 offset, I am interested.
Post by tehjeffman on Jan 31, 2015 16:42:32 GMT
The Advanti Storm are a horible wheel do to the fact that the spokes stick out making it very easy to destroy a wheel on curbing. If you W2W and rub you can destroy them even worse. I will be testing 9" wheels with differenct options shortly. I really thing a 15x9 6UL with a 10mm or 15mm spacer will work fine and reality it's the suspension travel and spring rates that make it rub with a soft side wall tire. Real race suspension and race tires are the key.
Post by linuxd00d on Jan 31, 2015 17:24:30 GMT
Could the 6UL be made in 0-offset as a group buy custom order?
Post by tehjeffman on Jan 31, 2015 17:34:30 GMT
Could the 6UL be made in 0-offset as a group buy custom order? It could but Emilio would refuse to do it and he has a point. By going to a 0 you are ruining the scrub radius the miata was designed on.
Post by jwagner on Feb 1, 2015 3:51:44 GMT
The Advanti Storm are a horible wheel do to the fact that the spokes stick out making it very easy to destroy a wheel on curbing. If you W2W and rub you can destroy them even worse. Cross that one off the list.
Post by mdizz7 on Feb 1, 2015 16:45:29 GMT
Hey guys, I just put in my order a few weeks ago and I'm looking for wheels under $100 per wheel. I find th weight discussion very interesting. I'm currently looking at some Bassett lightweight steel wheels that are 17lbs for 15x8 (http://www.bassettwheel.com/dhole_lightweight.html). The nice thing about these wheels is that I can get pretty much whatever offset (including negative) I want. The XXRs are just under 17lbs but is a 17lb wheel a big mistake?
