Post by airforceone on Oct 1, 2011 14:58:59 GMT
Just had a clean round the garage and found these, a pair of focus rear calipers, forgot I had them, I've put them on here before but had no replies. . . . . They could do with a good clean and are supplied without the carriers (they were siezed to the car I got these from). Only looking for what I paid for them from the Scrappy, so £45 including postage (to UK that is). PM me if interested. Ned.
Post by flynn on Oct 1, 2011 18:16:53 GMT
Hi Ned, I like the overall look of the car, keep on going with the good work Where did you get the plastic blocks from who are holding the radiator pipes? And how do you call them? cheers, Arjen What he said Where did you get them from?
Post by airforceone on Oct 1, 2011 18:29:11 GMT
Just do a search on eBay for pipe clamps, there are loads, double ones are about £4, 3 is enough that's all I got two for the front and one for the back.
Ned
Post by ncohen on Oct 9, 2011 4:09:01 GMT
Hi, could you post some pictures or explain how you mounted the pipe clamps to the chassis? Thanks
Post by airforceone on Oct 9, 2011 6:36:38 GMT
I was thinking of putting rivnuts in the chassis but the centre tube is quite small and the rivnut fr an m8 bolt requires that quite a large hole be drilled. I think I will connect them to the centre tunnel, some how . Ned
Post by scottie999 on Oct 9, 2011 10:07:43 GMT
4mm holes and tec screws work quite well...................
Post by airforceone on Oct 18, 2011 19:57:53 GMT
Well just waiting on some bits and pieces turning up namely clutch kit, but these bad boy's turned up today. The guy makes the from billet steel, stronger than original shafts and they look the biz and less than £100 including delivery. . Ned
Post by jonb2010 on Oct 18, 2011 20:03:45 GMT
Oooh they do look nice. Have you got a link ?
Post by airforceone on Oct 18, 2011 20:24:03 GMT
Post by airforceone on Oct 19, 2011 11:23:44 GMT
Managed to get a few more bits done, nothing major. Just as I was starting this new entry my new clutch kit and handbrake cable turned up so hopefully will be able to crack on again at the weekend. I eventually got round to removing the clutch from the the 2.0 litre engine. This is it sitting next to the 1.8 flywheel. . Just need to remove this one then I can put the 1.8 wheel on with the new 1.8 clutch. Luckily bought one of these kits to help remove the flywheel, as taking it off the old engine was a nightmare. . Eventually got round to finishing off the Accelerator pedal. Also fitted the Wilwood pedals and the Res hoses. Tried to connect the hoses to the brake/clutch Res and the connector split only to be expected I suppose, it is 13 years old so need to source a new one. . Also got some T-bolt clamps for the cooling pipes, been told they are better than normal worm screw type. Also used rubberised p-clips to mount the nice Viper brake cables to the same clamps. Made a bracket for the 4-way connector to sit on, want to keep the brake switch vertical as I've read on here that they tend to leak. Will be using PTFE tape on all brake line connections prior to priming the system. . Few other small jobs done. Fitted the gear stick, attached a new front handbrake cable to the lever and put the fuel tank cover in just to see what it looked like . Couple of ongoing jobs, centre tunnel cut just need to clean it up and put some vinyl on it. Rear bulkhead almost finished may just paint that as the fuel tank covers most of it, undecided yet, and also in the process of fitting rear wheel wing stays so more pics soon. So thats 3 months I've had the kit now, not getting as much time on the kit as I would like but still loving it. Ned
Post by flynn on Oct 19, 2011 13:27:38 GMT
I think youve done really well for 3 months work. Looking good
Post by ncohen on Oct 19, 2011 14:14:34 GMT
Looking good! thanks for taking clearer pics of the pedal assembly!
Are your brake lines the pre-made ones from rtr?
Thanks
Post by mabbs on Oct 19, 2011 15:53:15 GMT
Well just waiting on some bits and pieces turning up namely clutch kit, but these bad boy's turned up today. The guy makes the from billet steel, stronger than original shafts and they look the biz and less than £100 including delivery. . Ned You got those quick !! They are far better quality than the OEM units and feel at lot more robust - a bargain
Post by JimK on Oct 19, 2011 20:20:12 GMT
Hi Ned Looking very good, you have some quality components there. Looks like another quality build! Regards Jim
Post by airforceone on Oct 19, 2011 20:49:42 GMT
Thanks Jim.
You could spend an absolute fortune on these things.
I'm a bit miffed at myself at the moment, I lost the battery charger for my camera several months ago so have been Using my camera fone, the pictures are really poor quality, It looks a lot better than these pictures show.
Need to keep up with the joneses, well you and Mabbs.
Ned
