Post by freshlikesushi on May 6, 2012 19:55:11 GMT
Andy888
Exocet Builder
Post by Andy888 on May 6, 2012 21:20:44 GMT
Nice video! This is the nicest finished Exocet I have seen so far.
Post by Tim Kerr on May 6, 2012 22:01:17 GMT
How's yours coming along Andy? I have been busy running the engine in only 700 more miles!!
Andy888
Exocet Builder
Post by Andy888 on May 7, 2012 18:16:29 GMT
Still chipping away at it Tim. Discovered last night the radiator is 1" too low to fit the nose cone on! Also waiting for a chap to make us a new transmission tunnel since the MEV supplied one doesn't fit in the slightest...
Post by John B on May 7, 2012 21:00:13 GMT
Looks awsome, hope mine looks as good when completed.
Post by Kevin Patrick on Jun 14, 2012 13:01:24 GMT
Post by freshlikesushi on Jun 14, 2012 17:30:42 GMT
looks SOOOO good.
i see your seat rubs where mine does
Post by mabbs on Jun 14, 2012 18:37:34 GMT
Fantastic job Kevin. Looks amazing
Post by h5ngs on Jun 14, 2012 18:50:42 GMT
Looks awesome, well done can i ask what the final weigh in was on your car?
Post by Kevin Patrick on Jul 16, 2012 23:24:48 GMT
Still have not had her weighed yet. Hoping to use some proper scales soon.
Post by Kevin Patrick on Jul 16, 2012 23:29:49 GMT
Any other Exocet builders using Racelands/Rokkor/similar and unhappy with their spring rates? ME TOO. I found some springs here in the US that can be swapped out - 150 lbs in the front and 100 lbs in the rear is what I am running now. All I can say is that after driving on the Racelands with 300+ lbs rates I fell in love with the car again after making the swap. Definitely an inexpensive option to fix the racelands/rokkors if you have gone that route. Still not perfect, but much more compliant.
Post by freshlikesushi on Jul 17, 2012 0:43:51 GMT
MAY want to get different lengths if you ever do it again. that length will limit your height if you ever want to lower it.
and look into the Fat Cat motorsports bumpstops. the guys on CR.net are having good results with them on the cheaper coilovers with giving a little more suspension travel which will be important with the lighter spring rates as well
Post by h5ngs on Sept 29, 2012 16:38:37 GMT
Kev, how did you mount your rear lights, i'm planning on using some cheap and nasty ones to get through iva then place them where i want them, if you have any pictures or could take some that would be great. Cheers Craig.
Post by Kevin Patrick on Oct 2, 2012 19:55:22 GMT
h5ngs - very simple aluminum angle with a slice taken off to clear the bolt-on roll bar. Might readdress this winter for something a little nicer.
Post by freshlikesushi on Oct 9, 2012 12:50:57 GMT
the lights i use flush mounted into the trunk would look smashing id say? they are trailer lights you can get at walmart and LED Exocet by Flsimages, on Flickr
