Post by Kevin Patrick on Jan 18, 2011 19:28:25 GMT
Post by Kevin Patrick on Jan 18, 2011 19:28:49 GMT
Post by Kevin Patrick on Jan 18, 2011 19:29:40 GMT
I had a little daylight left after attacking the crate with a chainsaw so I decided to do some quick mockups to test fit components. First, I tried out the body panels. Next, I bolted up the front/rear sub frames and steering column. Then laid out the interior panels, stock seat, fuel tank and MSA roll bar. (BTW, the MSA roll bar is amazing.) Front Subframe and steering column Steering Column, Wheel and stock seat Cockpit Fuel Tank Fuel tank and rear sub frame Rear sub frame Mockup Everything fit perfectly. Now to tear it down so the parts can be prepared for the powder coater. I have decided to powder coat everything including the suspension components.
Post by Kevin Patrick on Jan 18, 2011 19:32:59 GMT
Ha, just realized that the title of one of the photos was changed from "c - o - c - k - p - i - t" to "thingypit"
Andy888
Exocet Builder
Post by Andy888 on Jan 18, 2011 23:02:33 GMT
Nice!! Love the roll over hoop. Looks much more substantial than the standard one
Post by Kevin Patrick on Jan 24, 2011 15:29:51 GMT
Post by speed7bump on Jan 26, 2011 18:30:57 GMT
Kevin - check PM's.
Post by dinosaurjuice on Jan 26, 2011 19:10:32 GMT
nice to see a bare chassis, the quality of fabrication looks
Post by Kevin Patrick on Jan 29, 2011 23:31:51 GMT
Picked up the frame and suspension today from the powder coater. Went with a gloss black on everything. Very happy with the quality of the work. The donor parts are looking better than ever. Front and Rear Subframes Wing Stays and Steering Column mount Suspension Components Frame and MSA-spec roll bar baking in the oven After baking MSA-spec roll bar Back home safe
Post by Kevin Patrick on Feb 14, 2011 17:00:32 GMT
February has been busier than expected, but I have been able to make a little more progress on the Exocet the last two weeks. Currently waiting on a few more items to come back from the powder coater. Floor is cut Cutting the floor out video: Sorting the suspension bushings on the parts table New Inner Tie Rods New Outer Tie Rod Ends New Lower Ball Joints New Front Hubs New Steering Wheel/Boss Kit 32mm Wheel Spacers Steering Rack Plug Kit from MiataRoadster Further assembly of the steering rack with new tie rods/ends Pressing in the new suspension bushings Painting steering rack mounts and differential bushing holders
olberj
SC Rocketeer
Post by olberj on Feb 14, 2011 22:36:41 GMT
Brilliant. Love seeing builds in this much detail, keep it up mate.
Post by Kevin Patrick on Feb 21, 2011 20:10:31 GMT
Atlanta had some great weather this weekend so I took advantage of the higher temperatures to get some more painting done. Lots of wire wheeling/sanding of the original pieces (BORING!) For paint, I used VHT Roll Bar & Chassis paint which should be safe up to 250 degrees. www.vhtpaint.com/rollbarchassis.html Anti roll bars Anti roll bar end links and mounts Front Hub dust caps More parts came in last week including the new steering rack boots/bellows kit And the new Super Pro poly steering rack bushings Steering rack is officially done. Depowered using the Flyin Miata method, new boots, new inner tie rods, new outer tie rod ends and a plug kit from Miataroadster. Next, flipped the Exocet upside down Then cleaned up the sides of the floor with a file and fit them on the chassis That high gloss powder coating really shines Next up, floor drilling and rivet gun time
Post by Kevin Patrick on Feb 23, 2011 18:34:13 GMT
Had a few more parts delivered yesterday: Clutch Master and Slave Cylinders Cross drilled and slotted brake rotors and pads Axles Stainless steel header
Post by Kevin Patrick on Feb 28, 2011 4:16:15 GMT
Installed all bushings, bearings, hubs and ball joints. Front & Rear Front Rear
Post by Kevin Patrick on Feb 28, 2011 4:16:46 GMT
