Post by Stiggy on Oct 2, 2017 16:01:39 GMT
One thing to watch for is as you add items to comply that you don't add items that don't in the process. In this case I am sure Ian has already covered the edges of his brackets.
Post by Shane on Oct 2, 2017 17:09:55 GMT
Already done it will be posting detailed pictures soon so people can run their eyes over before I book it
Post by Shane on Oct 4, 2017 17:54:56 GMT
Post by mikeeyboy on Oct 4, 2017 19:41:00 GMT
Car looks great!
Post by Shane on Oct 4, 2017 19:58:07 GMT
Post by gwnwar on Oct 5, 2017 4:47:17 GMT
Might need some edge trim on the bracket vertical part that is bolted to the frame.. Gaps on the mount bolt nut for the lamps..Looking good..
Post by Shane on Oct 6, 2017 15:29:39 GMT
Might need some edge trim on the bracket vertical part that is bolted to the frame.. Gaps on the mount bolt nut for the lamps..Looking good.. I dont think the 100mm ball will be able to contact it as there are too many obstructions around it, but will take another look
Post by gwnwar on Oct 6, 2017 16:07:53 GMT
just take a few feet of it with you and some tools..
Post by Stiggy on Oct 6, 2017 17:40:14 GMT
not an IVA issue but the edge of the GRP bonnet will damage the chassis paint without protection. You can use the seal from the MX5 boot, failing that you need some of;
Post by Shane on Oct 6, 2017 18:36:58 GMT
not an IVA issue but the edge of the GRP bonnet will damage the chassis paint without protection. You can use the seal from the MX5 boot, failing that you need some of; Thanks Stuart, will order some now!
Post by dave on Oct 8, 2017 20:13:45 GMT
Hi Shane, cars looking good mate I also mounted my lights as you did first so will have to adjust . Would you mind posting a couple of pics of the harness bar mounts (bolts)and how you fitted the harness to it. Also which side mirror mounts did you go for. Cheers Dave
Post by Shane on Oct 8, 2017 23:33:21 GMT
Hi Shane, cars looking good mate I also mounted my lights as you did first so will have to adjust . Would you mind posting a couple of pics of the harness bar mounts (bolts)and how you fitted the harness to it. Also which side mirror mounts did you go for. Cheers Dave Thanks Dave, what do you mean by harness bar mounts?
Post by Shane on Oct 9, 2017 14:58:58 GMT
Post by dave on Oct 9, 2017 20:23:53 GMT
Hi Shane, cars looking good mate I also mounted my lights as you did first so will have to adjust . Would you mind posting a couple of pics of the harness bar mounts (bolts)and how you fitted the harness to it. Also which side mirror mounts did you go for. Cheers Dave Thanks Dave, what do you mean by harness bar mounts? At the point where it bolts to the chassis and how the harness is wrapped around, cheers
Post by Shane on Oct 9, 2017 20:29:13 GMT
