Post by Shane on Sept 25, 2017 17:18:34 GMT
Post by Shane on Sept 25, 2017 17:35:39 GMT
Post by p5curly on Sept 25, 2017 17:39:23 GMT
Don't turn the headlights as we already did that to your kit before we gave it back to to you the glass may say top on the headlight
Post by Shane on Sept 25, 2017 17:47:42 GMT
Don't turn the headlights as we already did that to your kit before we gave it back to to you the glass may say top on the headlight I think he means turn the entire housing so that the indicator which is on the side at the moment is then at the top to ensure they can be seen from the opposite side, as the manual states: "Each lamp and reflector must be positioned such as to provide an “apparent surface”. At least 50% of the “apparent surface” of each lamp or reflector must be visible from any point within the relevant angles." (the angles are 80-45%) I think it will be fine as is when the lights are at the correct height due to the stalks they are fitted to. Cheers
Post by p5curly on Sept 25, 2017 17:53:28 GMT
Are you going to bolt it at the bottom then not at 90 degrees as it is fitted now
Post by Shane on Sept 25, 2017 17:56:05 GMT
Are you going to bolt it at the bottom then not at 90 degrees as it is fitted now Exactly as it is now mate just higher so it meets the height requirements
Post by p5curly on Sept 25, 2017 18:01:34 GMT
The indicators are fine on the side as both our cars passed with those lights set that way
Post by p5curly on Sept 25, 2017 18:32:42 GMT
Post by Stiggy on Sept 25, 2017 19:58:13 GMT
white reflectors on the back, interesting, what do you think Shane, good?
Post by Shane on Sept 25, 2017 20:04:27 GMT
white reflectors on the back, interesting, what do you think Shane, good? No idea Stuart, that's why I asked, im not sure what a stupid question is anymore, only a few hours ago i though the supplied lights fitted to the welded brackets on the kit would have been IVA compliant, turns out I was wrong there aswell Sarcasm aside, I assume red reflectors would be fine?!?
Post by p5curly on Sept 25, 2017 20:23:47 GMT
Are you now saying the headlights are no good or are you taking the piss
Post by Shane on Sept 25, 2017 20:27:36 GMT
Are you now saying the headlights are no good or are you taking the piss The headlights themselves are fine, but fitting them to the bracket that is welded onto the chassis, positions them to low for the IVA
Post by Stiggy on Sept 25, 2017 22:27:41 GMT
The bracket on the chassis is to assist builders mount lights without welding. It is not drilled and is not supposed to be a direct mount for any and every type of light.
Post by gwnwar on Sept 25, 2017 22:54:31 GMT
Shane.. With the side repeaters did you see this in the ad.. NOTE:: Unusually, on this lamp, the 'E' mark is on the rear of the lamp and cannot be seen when installed. Take a pic of the "E" if you can't see it installed..
Sold Singulary
Did you order 2..
Post by kiwicanfly on Sept 25, 2017 23:17:52 GMT
The bracket on the chassis is to assist builders mount lights without welding. It is not drilled and is not supposed to be a direct mount for any and every type of light. Is it suited to directly fitting any make of light and, if so, which type is that? Bugger, reread and see that you used the word 'any' so I guess the answer to my question is none
