Post by Shane on Sept 26, 2017 6:28:12 GMT
Shane.. With the side repeaters did you see this in the ad.. NOTE:: Unusually, on this lamp, the 'E' mark is on the rear of the lamp and cannot be seen when installed. Take a pic of the "E" if you can't see it installed.. Sold Singulary Did you order 2.. Yes I saw that, thanks George
Post by Shane on Sept 26, 2017 6:30:08 GMT
Are red reflectors ok Stuart? ( Stiggy)
Post by Stiggy on Sept 26, 2017 9:02:47 GMT
For IVA the car looks like Mickey Mouse with big ears (headlights) sticking out. If you bolt a piece on to mount the headlights correctly for IVA then when it comes to your first MOT 3 years down the line the lights will pass if lowered and looking more sensible.
Post by Stiggy on Sept 26, 2017 9:05:19 GMT
Are red reflectors ok Stuart? ( Stiggy ) We did this one. I said use rubber not white or red reflectors which could also have sharp edges.
Post by Shane on Sept 27, 2017 17:10:21 GMT
Update on headlight positioning, If i am understanding the IVA manual and the very helpful post by jgilbert then they are bang on and dont need adjusting. They are: 350mm from the outside of the wing (max 400mm) 550mm from the floor (minimum 500mm maximum 1200mm)
Post by ian360 on Sept 28, 2017 8:18:51 GMT
The position height / width is fine but need to check the visible angles as well. I think your nose will obstruct the 20degree for opposite side angle, believe you still need to see at least 50% of the light? Chapter 20 of manual gives all the angles.
I did the same and there is an obstruction using that mounting.
Post by Shane on Sept 28, 2017 15:12:20 GMT
I can't see then failing mate I can see them from the other side of the car crouched down at the hight of the nose cone, shocked if they do
Post by ian360 on Sept 29, 2017 12:38:08 GMT
Yep - I did the same, it's very rough and I'm not sure you are seeing "50% of the apparent surface" from the other side.
For the sake of a bracket wasn't going to risk it, that's not an easy fix on the day of the test.
Post by Shane on Sept 29, 2017 17:36:43 GMT
For the sake of a bracket wasn't going to risk it, that's not an easy fix on the day of the test. Just saw the bracket you made on you build thread, nice and simple, may give it a go, just in case
ybot19
Junior
1990 eunos roadster
Post by ybot19 on Sept 29, 2017 18:01:10 GMT
Hi Shane, saw your build at MEV owners day looks good. Had my Iva a month ago and my light failed in the position yours are in the manual states it is only 20 degrees inwards for sidelights and indicators not headlights, therefore need lifting up above the bodywork. I'm in the Facebook group if you want to see how I did mine.
ybot19
Junior
1990 eunos roadster
Post by ybot19 on Sept 29, 2017 18:04:37 GMT
I can also show you why the dominator beam pattern fails and how I've adjusted it internally for a flat beam pattern no rotation of the lens required
Post by Shane on Sept 29, 2017 18:12:09 GMT
Hi Shane, saw your build at MEV owners day looks good. Had my Iva a month ago and my light failed in the position yours are in the manual states it is only 20 degrees inwards for sidelights and indicators not headlights, therefore need lifting up above the bodywork. I'm in the Facebook group if you want to see how I did mine. What's you name mate so I can search in the FB group
Post by freshp5 on Oct 2, 2017 11:21:42 GMT
I put 2 cars throw Iva with same light in same place and pass
Post by Stiggy on Oct 2, 2017 12:19:05 GMT
Hi Shane, saw your build at MEV owners day looks good. Had my Iva a month ago and my light failed in the position yours are in the manual states it is only 20 degrees inwards for sidelights and indicators not headlights, therefore need lifting up above the bodywork. I'm in the Facebook group if you want to see how I did mine. Or you could explain on here as the question is asked here. We now have people wondering.
Post by Shane on Oct 2, 2017 14:53:40 GMT
Hi Shane, saw your build at MEV owners day looks good. Had my Iva a month ago and my light failed in the position yours are in the manual states it is only 20 degrees inwards for sidelights and indicators not headlights, therefore need lifting up above the bodywork. I'm in the Facebook group if you want to see how I did mine. Or you could explain on here as the question is asked here. We now have people wondering. Same as ian360, here is Ians image I hope he doesn't mind me posting it here as its off his build!
