Post by laube on Nov 28, 2016 22:26:53 GMT
Hi All,
My name is Iwan and I'm from Holland, Utrecht to be more specific. By coincidence I walked in to an unfinished eco exo r project. The owner a colleague had no time and space to proceed the build and luckily handed over the project to me.
Herby the start and some simple facts on the build.
Took over the project from a colleague. Took apart the burgman Base plate is already placed on the frame and the frame is powder coated ( would have been easier to start with an blank sheet )
I will first upload some pics to give you an idea
Regards
Iwan
Post by laube on Nov 29, 2016 5:22:03 GMT
Post by laube on Nov 29, 2016 5:35:40 GMT
Bringing the kit home
Post by laube on Nov 29, 2016 5:36:29 GMT
Stripping the Burgman
Post by laube on Nov 29, 2016 5:46:19 GMT
Start assembling the front stearing section, the bottom rod ends have been drilled with 5 mm holes. This seems quite fragile to me, also the rod end is hollow and therefore in my opinion not perfect to put tention on. Made a small bracket to provide additional support. Fixed the rod end with a bolt to the bracket and than drilled the existing 5 mm holes upto 6 mm. This should provide a bigger safety factor. Because the frame was already coated at start this build will be basically bolted together.
Post by laube on Nov 29, 2016 5:50:09 GMT
Post by laube on Nov 29, 2016 18:10:30 GMT
Post by laube on Nov 29, 2016 18:15:29 GMT
 Steering wheel arrived, as all other parts I will try when possible to use second hand parts. See it as a challange 😆 to maintain the quality I'm after but use low cost second hand parts.
Post by laube on Nov 30, 2016 6:53:58 GMT
Post by laube on Dec 1, 2016 8:50:25 GMT
At the stage of assembling the front wheel section but run in to an issue. The rims from my 99 donor seem te be different than the rims I see on all eco exo's on this forum. when mountimg the steering ball joints as described in the manual they will hit the brake disc.... See example below. Only option is see now is to mount the steering ball joint approaching the fork bracket from the top. Not ideal since the angle it's in don't seem te be ok. any advice or solutions are welcome.
Post by edvb on Dec 3, 2016 13:52:30 GMT
Hi laube
You best solution might be to find a pair of later model rims, caliper and wheels. The geometry is such that you do not want to change that from the original. You could also ask Stuart what his thoughts on this might be.
Edward
Post by edvb on Dec 3, 2016 14:04:19 GMT
Also did you put a spacer between the rose joint and mounting plate? I did not as there was no room for one. flic.kr/p/jRFcoD
Post by laube on Dec 3, 2016 14:30:06 GMT
Hi Edward, Going your route with the conical spacer on top was the first idea,however when mounting I found that the rubber on the joint was "to much" pressed together. At this moment I cut down the front part of the bracket and made one resting on the origional. This lifts the joint apr. 6mm and i have brought the hole slightly foreward. This provides sufficient clearance. Still needs te be painted but below a picture
Post by edvb on Dec 3, 2016 14:49:52 GMT
Great that should work fine. Since mine was not painted yet I was able to weld a thick spacer on top and had it reamed for a proper fit. Good to hear you have that solved.
Post by laube on Dec 3, 2016 15:32:07 GMT
Hi Edward,
Really enjoying the build and reading trough the other building posts. Also hope to get in contact with Erik once to sort out some details about legislation.
Having it coated already does force you to use a more bolt on way of building but sofar all good.
Will post some more pictures after the weekend.
Iwan
