Post by tlight on Dec 31, 2010 15:35:55 GMT
Then after removal of fuel tank, removal of boot lid hinges & throttle cable Boys start to strip front end... and improved access by lifting engine off
Post by tlight on Dec 31, 2010 15:42:12 GMT
Finally shifted the lower wishbone bolts (new bolts required). Next jobs for backend, get bigger angle grinder disk to get the head off the O/S ABS sensor bracket, circlip pliers to split the diff, nut splitter to break the propshaft nuts...then knock out the suspension bushes and then drill/tap out sheared ABS sensor bolts, wire brush & hammerite / blast & powder coat all the backend parts.
Post by tlight on Dec 31, 2010 15:49:02 GMT
Post by tlight on Jan 2, 2011 13:37:51 GMT
No time to play today, so Silver Smooth & Black Hammered Hammerite ordered for the non powder coated parts, (from e-bay, a lot cheaper than B&Q or Homebase) cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=140310181526&ssPageName=STRK:MEWNX:IT. I am working on the theroy that the aluminuim (paint silver) will clean up better than the steel (paint black). On the powertrain/chassis, the Engine Block & Calipers will be Red. Also bought a set of 3 nut splitters ordered from Abbey Power Tools. Body shell now completely stripped & available for the scrap man. Anyone tried selling on e-bay (minus ID), mine has damage to N/S rear wing, but with only 15K would be a good for an 'off' road racer ?
Post by tlight on Jan 8, 2011 18:57:25 GMT
Time for the boring bit - removing seized bolts and cleaning parts...
Post by tlight on Jan 8, 2011 19:02:42 GMT
Preperation of parts for shot blasting & powder coating. All threads protected with nuts & bolts (to save re-tapoping threads) and all oil/grease removed to ensure good paint adhereance.
Post by tlight on Jan 8, 2011 19:05:02 GMT
Shock absorbers & rubbers washed & prepared for painting.
Post by tlight on Jan 8, 2011 19:06:04 GMT
Cleaning & removing the sponge body seal on the fuel tank, prior to painting.
Post by tlight on Jan 8, 2011 19:10:15 GMT
And time for a bit of wire brushing of the back axle (still not got the circlip pliers, and the propshaft bolts didn't want to budge so I could not see the point of cutting off just to replace....)
Post by tlight on Jan 8, 2011 19:16:22 GMT
Post by Kevin Patrick on Jan 8, 2011 19:44:47 GMT
Cleaning & removing the sponge body seal on the fuel tank, prior to painting. What method worked best when you removed the sponge body seal?
Post by tlight on Jan 8, 2011 20:22:00 GMT
Kevin,
Erm, probably not the recommended method...we're using the petrol from the fuel tank on a rag, its comming away quite easily, Joseph recons he needs just another 20mins in the morning and it will be completly off.
Tim
Post by tlight on Jan 9, 2011 17:36:25 GMT
Bodyshell gets collected tommorow, so few last jobs...flexi brake pipe mounting point... which needs adding to the front sub frame...
Post by tlight on Jan 9, 2011 17:40:49 GMT
Bought some red flexi brake pipes, so quick trial in exisiting bracket Flexi held by a clip & hex in the bracket Clean up front sub frame in preparation for welding on new bracket & powder coating...
Post by tlight on Jan 9, 2011 17:48:03 GMT
Parts off for powder coating...
