Post by iparnell on Jan 5, 2016 20:56:12 GMT
That should do the job...mine did. They are not facing the wrong way.
Post by jgilbert on Jan 5, 2016 21:25:54 GMT
Hope this works out OK for IVA Tim, looks plenty wide enough to me. Although yours look a bit more forward. Found this picture of mine and I reckon they were only 2" out from the side of the car and passed.
Post by tlight on Jan 5, 2016 21:42:58 GMT
Great Iparnell & John ! (Side markers definitely need to face backwards)
Next question, I mounted seats like John, with brackets welded to runners and screwed to seats. The runners are then bolted through the box section with a nylock on the underside of the floor pan.
I've read about strips of plate between bolts and also crush tubes. What will IVA expect/want ? Struggling to see the seat mounting specifics in the IVA manual...
Post by jgilbert on Jan 5, 2016 22:13:45 GMT
Great Iparnell & John ! (Side markers definitely need to face backwards) Next question, I mounted seats like John, with brackets welded to runners and screwed to seats. The runners are then bolted through the box section with a nylock on the underside of the floor pan. I've read about strips of plate between bolts and also crush tubes. What will IVA expect/want ? Struggling to see the seat mounting specifics in the IVA manual... Tim, I didn't fit 'crush tubes' drilled through the box sections and mounted the runners directly to these (I did grind off the thin lip on the bottom of the runners for more contact area). Can't remember if I used 8 or 10mm 8.8 grade bolts with large penny washers and nylon nuts. Mr IVA man happy with what I did.
Post by tlight on Nov 26, 2016 15:24:11 GMT
Fitted penny washers and Toyo TR1 tyres today, getting booked in for IVA.
Post by shawtobuild on Apr 27, 2017 20:30:46 GMT
Hi, New to forum and reading through lots of build threads to gauge my ability and potential pitfalls. Just wanted to congratulate you and your son as it has to be one of the best i've read with so much detail and information. Did you ever get it finished? Simon
Post by tlight on Jul 22, 2017 5:18:49 GMT
IVA in a fortnight ! Fingers crossed
Post by jgilbert on Jul 22, 2017 21:00:07 GMT
Good luck!!!
Post by Fin on Jul 27, 2017 9:29:53 GMT
Great Iparnell & John ! (Side markers definitely need to face backwards) Next question, I mounted seats like John, with brackets welded to runners and screwed to seats. The runners are then bolted through the box section with a nylock on the underside of the floor pan. I've read about strips of plate between bolts and also crush tubes. What will IVA expect/want ? Struggling to see the seat mounting specifics in the IVA manual... I've mounted my GRP seats in a similar fashion with MEV mounts and Mk2.5 rails using M8 bolts and penny washers, but chose to insert bolts from bottom up in the belief it might be less to snag on humps & sleeping policemen with just the bolt head underneath. Any thought?
Post by tlight on Jul 30, 2017 13:20:13 GMT
Sounds logical. I've had no experience over speed humps so can't comment.
Post by tlight on Jul 30, 2017 13:23:27 GMT
IVA fail.
Front indicators too dim.
Connected two of the ABS pipes the wrong way round.
Short seat belt bolt.
Short sub frame bolt.
Speedo visibility.
Post by miket on Jul 31, 2017 16:41:40 GMT
Sorry to hear that - so close but so far. I guess there's a silver lining in finding the ABS issue.
How come indicators were too dim?! .. I imagine you used the bulbs that came with them - odd one. Speedo visibility seems an odd one too but I haven't gone back to study where you put it that's so invisible.
Feels like you should be fine for the retest - fingers crossed anyway.
Post by tlight on Sept 7, 2017 18:22:10 GMT
IVA passed, insurance sorted, just waiting on the posted DVLA form
