Post by tlight on Nov 29, 2013 20:08:20 GMT
Mounted rear lamp brackets
Post by pincherrn on Nov 29, 2013 20:09:59 GMT
Hi Tim,
I like the top one of the three. They look really smart. I liked the idea of a set of the Kellermann lights all round as they do a rear set with stop /tail / indicators too. Not sure how the IVA would see it though. I'm putting Dominators on the front which have sidelights built in so don't need the indicator / sidelights now.
Colin
Post by jgilbert on Nov 29, 2013 20:40:25 GMT
Think I'm going with the Quadtech lights.
Post by gwnwar on Nov 29, 2013 23:57:03 GMT
What happened to that fuel tank.. is it your beating post when thing don't work out..
Post by tlight on Nov 30, 2013 6:36:54 GMT
Filler neck clearance - didn't measure - so i modified with a big hammer
Post by tlight on Nov 30, 2013 8:05:45 GMT
They do look like the best option. Tin
Post by tlight on Nov 30, 2013 8:16:40 GMT
Tool storage parts (minus padlock) Just got to book a time with my mum and her sewing machine....
Post by tlight on Dec 2, 2013 13:08:50 GMT
Final dash bracket ready to install
Post by tlight on Dec 2, 2013 13:13:59 GMT
Revised 50mm higher radiator brackets powder coated - ready to install
Post by tlight on Dec 2, 2013 13:15:53 GMT
Bonnet bracket May redesign later, for a more finished look (it's wonky but does the job)
Post by tlight on Dec 2, 2013 21:57:39 GMT
Revised radiator brackets fitted, lifting unit up 50mm. The radiator cap now sits right under the bonnet aero catch - so going to see if I can get the latch mounted to the cap. In hind sight I should have mounted aero catch horizontal layout, rather than the vertical layout (if you know what I mean). Radiator ground clearance improved Radiator top view
Post by tlight on Dec 2, 2013 22:01:08 GMT
Trimmed bonnet edges, will need to improve gap. I am not sure about nose cone trim...
Post by gwnwar on Dec 3, 2013 6:36:49 GMT
Deep 6 the nose cone trim.. Latch in the cap now that is different.. How about doing that some how but have it seal the radiator there.. Then install a cap unit in the upper radiator hose.. Remember it would have to be the highest part in the coolant system to bleed the system..
Post by tlight on Dec 3, 2013 9:12:44 GMT
For front bonnet catch, thinking of making a 2mm plate, weld on a loop & then attach to ears of the radiator cap?
Post by tlight on Dec 3, 2013 14:19:24 GMT
Seat frame runners ready for fitment
