Post by jgilbert on Dec 3, 2013 15:08:06 GMT
HaHa, recognise the design. Good work.
Post by tlight on Dec 3, 2013 21:17:22 GMT
Dash board pod mounted
Post by tlight on Dec 3, 2013 21:19:07 GMT
Seat on runners (flange button head fasteners ordered)
Post by tlight on Dec 3, 2013 21:20:19 GMT
Looking like a car...
Post by tlight on Dec 3, 2013 21:21:26 GMT
Rear lamps mounted
Post by jgilbert on Dec 3, 2013 21:49:01 GMT
Coming along very nicely, lots of progress. keep the photos coming.
Post by gwnwar on Dec 4, 2013 4:40:10 GMT
Is the top seat belt mount going to work OK.. Seems like the belt has to go way outward around seat back side..then down to latch.. Is this going to hold you in OK?? Hope it passes safety check..
Post by tlight on Dec 4, 2013 5:55:30 GMT
I'll have a trial when it's all bolted down, picture with crash test dummy to follow.....
Post by tlight on Dec 4, 2013 21:14:52 GMT
Highs and low tonight.
Exhaust hanger fitted & back box.
So next fuelled, connected battery, ignition light came on (yeay) engine turned over (yeay).....unfortunately didn't start (boo).
Wondering if fuel pipes are connected correctly?
Post by gwnwar on Dec 5, 2013 6:01:54 GMT
That is the first thing to check.. the most center tube from the tank unit is the supply to the engine.. Also there was a ground in the rear harness under the rear deck.. If tubing is right try jumping the FP and Grd in the dia box should run the fuel pump.. If that works start tracing wires.. and grounds
stubbers
Exocet Number 306
Post by stubbers on Dec 5, 2013 11:11:10 GMT
A quick way to check the fuel lines is to blow down them, the feed will be solid because of the pump, the return you will be able to blow down. Then feed to the front pipe on the manifold and return to the rear pipe next to the pressure regulator.
Or if you want to check if the pump is working properly take both pipes off put them into glass jars and turn the key, the feed should prime while cranking and for a few seconds after.
Rich
Post by gwnwar on Dec 5, 2013 15:23:44 GMT
The supply should be going to the front of the fuel rail..
Post by tlight on Dec 5, 2013 19:18:11 GMT
Thanks for the pointers, hopefully Sunday I'll get to the bottom of the issue, definitely feels like I've messed up the fuel pipe run
Post by tlight on Dec 8, 2013 16:53:12 GMT
Left the fuel system alone today. thought I would finish mounting the seats to the rails. Mounted with M8 x 30 flanged stainless steel button /Allen bolts, and pieces of 10mm hard rubber. Positioned, just need 8 fastenings to finish.
Post by gwnwar on Dec 8, 2013 23:35:40 GMT
Are you going to have to cut an oval in the seat back to feed seat belt outer lower mount and latch tab through.. Then finish with edge trim..
