Post by tlight on Nov 28, 2013 11:27:20 GMT
Painted headlamp brackets Lining up plenty to get assembled this weekend
Post by tlight on Nov 28, 2013 11:46:30 GMT
Sway bar now looks finished off.. were did you get the covers from for the hardware.. Think the lights will look better up front too. Hardware from eBay.
Post by tlight on Nov 28, 2013 22:02:43 GMT
Nose cone riv nut mountings installed, started drilling holes for mounting headlamps on front corner (but need a bigger drill bit) Won't reassemble the front end until the radiator is raised higher (50mm) for increased ground clearance. Planning on a combined LED Indicator / Sidelight to complete front end lighting.
Post by tlight on Nov 28, 2013 22:07:29 GMT
Exhaust centre section modified to make a little bit more parallel to the back end and reflector fitted. Next job will be mounting rear lamp brackets (to IVA requirements)
Post by jgilbert on Nov 28, 2013 22:23:08 GMT
Planning on a combined LED Indicator / Sidelight to complete front end lighting. What indicator / side lights you thinking off. I have the same headlights so need a combined unit ideally.
Post by tlight on Nov 28, 2013 22:45:52 GMT
Post by gwnwar on Nov 29, 2013 0:45:48 GMT
Nice units but will you be able to see them from rear of car.. I think it is 45deg out.. The end doesn't seem to show to the rear..
Post by tlight on Nov 29, 2013 6:00:03 GMT
Just reread. I can't see reference to that in Section 22 or 23 ? Or am I missing something?
Post by biggunz on Nov 29, 2013 8:24:48 GMT
Both the side lights and indicators should be visible 80 degrees outwards and 45 degrees inwards if you look at the tables at the bottom of chapters 22 and 23 under the column 'angles of visibility'
Shaun
Post by mathew on Nov 29, 2013 10:47:06 GMT
You may need an extra set of reflectors as im pretty sure where they are at the moment is more than 400mm from the edge of the car.
Post by pincherrn on Nov 29, 2013 14:27:58 GMT
Hi Tim,
I looked at these indicator / sidelights but if you notice the indicator is the inside portion of the housing and the sidelight the outer. I asked the guy if this was the case and he said they were as the foto. That seemed wrong to me so I didn't bother. There are some nice ones from Kellermann but they are expensive. I can't remember but I think I found another set similar to the ones you found but the right way round that weren't too expensive. I think the Kellermann ones are PL-1000 or similar.
Colin
Post by tlight on Nov 29, 2013 15:34:54 GMT
Post by tlight on Nov 29, 2013 19:39:33 GMT
You may need an extra set of reflectors as im pretty sure where they are at the moment is more than 400mm from the edge of the car. Just checked, your right. I was sticking them as per original, looks like a wing mounted reflector will be required.
Post by tlight on Nov 29, 2013 20:02:21 GMT
Revised radiator bracket to lift the radiator up 50mm First trial bonnet bracket...work in progress Radiator and bonnet brackets fitted Revised bend location required for mark 2 Bonnet bracket made for dashboard end.
Post by tlight on Nov 29, 2013 20:06:27 GMT
Front end with headlamps fitted
