Post by red5 on Nov 21, 2013 20:16:12 GMT
Tim - I went through the redesign phase toward the end of my build - then realised I could probably start the build over again and never get to the finish line ,I also would have nothing to do post IVA to escape into the garage to do
Post by tlight on Nov 21, 2013 20:38:05 GMT
I'm only think of the ground clearance issues, I'll only do the 'mission critical' issues. Nose cone brackets painted (added some lightening holes, which should aid Isopon P40 adhesion) The position idea, try get fitted on Sunday (mounting with 3off M5 riv nuts each side)
Post by tlight on Nov 21, 2013 20:45:00 GMT
Tank cover brackets lightened and powder coated
Post by tlight on Nov 21, 2013 20:47:42 GMT
Space to move the radiator up, increase ground clearance, just need to measure for new brackets...
Post by Toed64 on Nov 21, 2013 23:34:46 GMT
It's probably on your list, but your front anti-roll bar bolts will need lock washers or nyloc nuts...
Post by gwnwar on Nov 22, 2013 2:30:09 GMT
Toed You got that to print before I did.. noticed the same thing..
Post by tlight on Nov 22, 2013 5:17:37 GMT
Thanks guys. I'm sure I've got a few somewhere.
Post by tlight on Nov 22, 2013 16:19:50 GMT
Exhaust hanger bracket made, ready for trial fit once bent exhaust for the last time
Post by tlight on Nov 22, 2013 16:21:19 GMT
Headlamp bracket (first attempt, there will be a few...)
Post by tlight on Nov 22, 2013 16:22:47 GMT
My brother splitting the tyres at his garage ready to powder coat black
Post by tlight on Nov 22, 2013 16:24:36 GMT
All stripped...
Post by gwnwar on Nov 22, 2013 16:35:22 GMT
A little time with a file and some grit paper on the curb rash should make those rims look good.. Are you going total black or polish the high points.. Is he breaking the bead or washing the tire down..
Post by tlight on Nov 22, 2013 17:39:45 GMT
George
I was thinking total powder coated black, but I do quite like the Audi RS3 type look as well...
Not sure what you mean break the bead?
Tim
Post by tlight on Nov 22, 2013 17:43:06 GMT
Post by gwnwar on Nov 22, 2013 17:46:48 GMT
Bead must be a USA term.. The part of the tire that seals to the rim. Has to be broken away from the rim to dismount tire from rim.. What is UK term??
