Post by gwnwar on Nov 22, 2013 17:50:26 GMT
Yes like that Uudi look.. Thumbs up from me..
Post by tlight on Nov 22, 2013 18:22:29 GMT
We call it bead.
Post by tlight on Nov 22, 2013 20:17:39 GMT
Finally finished the smallest bracket, for the fuse box, and installed (on a Friday night !?!)
Post by tlight on Nov 22, 2013 20:23:25 GMT
My lighting idea... Sort of...mounted...
Post by gwnwar on Nov 23, 2013 5:13:52 GMT
How far/max back from the front of car can light be mounted??
Post by tlight on Nov 23, 2013 7:20:47 GMT
Post by red5 on Nov 23, 2013 8:05:58 GMT
Tim
Like the atom idea re headlight mounting - youll need to push your indicators forward though so they are visible from the opposite side,have a look at where they are on the atom clearly visible over the top of the nose when viewed from the opposite side at kerb height.
with the IVA in mind you can see how that car has evolved!
Post by tlight on Nov 23, 2013 9:06:48 GMT
So, I could change the headlamp bracket to my original thoughts (a 90 degree bent plate, hole each end, edged). The question would then be, what to do with location for indicators, sidelights & DLRL.
Post by tlight on Nov 23, 2013 13:02:39 GMT
Anti roll bar Nylocks in place
Post by gwnwar on Nov 23, 2013 16:04:10 GMT
Will you be hacked by IVA for length of threads out of the nut top. does it have to be capped?? Trying to learn your rules.
Post by tlight on Nov 23, 2013 17:39:00 GMT
Not sure, will change just purely on fact that it's 'bad practice' . I did think the cowl covering the bolts wouldn't impact IVA.
Post by tlight on Nov 24, 2013 20:30:59 GMT
Decided how to mount the tool box behind the drivers seat, going with Red Nylon Webbing, yacht bridges, leather eyelets & a padlock... eBay ordering tonight...
Post by tlight on Nov 24, 2013 20:36:08 GMT
Torqued king pins & front brake carriers, then bonded brackets to the fuel tank cover and nose cone. Ground clearance, will definitely need to move the radiator up 50mm... Shorter anti roll bar bolts to be ordered as well...
Post by gwnwar on Nov 25, 2013 1:40:38 GMT
Just were did you find a MX5 with king pins?? How much room do you have on top of radiator to raise it.. Has anyone added front skids to the nose area to save the nose and rad from high curbs. Like on a Corvette.. Why not add an alum. box to put tool pack in along with gloves test lamp and a soap and rag with a lock.. Make a matching one for other side for cheap rain suit..
Post by tlight on Nov 25, 2013 6:01:51 GMT
King pin, meant upper ball joint.
See pic last page, about 50mm to move rad up. Will end to make 4 new brackets.
I've still got the donor cars tie down straps if I need more storage options, just want to not suffer tool theft if I nip to the shops.
Wheels being powder coat black.
Revised 350mm friendly rear lamp brackets, brake carrier & exhaust bracket painted red.
Seat runner mounts nearly complete.
