Post by christof on May 27, 2011 13:16:13 GMT
lucky man, if you have mk2 onwards its just blanking plate at the back. recall this was the case on my mk2 1.8 - think it relied on front cam/crank sensors instead
I'd also recommend changing HT leads. Defo change cam cover seal if its original, careful not to catch rear lip if you still have coilpack in place. Remember small blobs of oil friendly silicone in corners (i use black one from halfrds, forget brand) and dont over tighten those poxy cam cover bolts! hoses on mine have started to go if touched (96). My favourite oil is Mobile 1 semisynth 10W40. and mx5 parts sell oem filters which have served me well. Gearbox likes fullysynth, check miata net etc If you track you car the ps fluid will boil over (if youve kept this). i have yellow stuff pads which are ok on track and seem to be lasting well.
thought i would spew it all out...
Post by tlight on May 28, 2011 12:02:59 GMT
Hi Tim, I had the same problem on my front upper wishbone ball joint threads. Managed to rescue the situation by filing a chamfer on the end of the stud then gently running a tiny file through the thread from the undamaged area below to create a 'run in' for the nut. As the stud is long enough, the nut, once tightened, is well in safety and saves having to change the whole wishbone. I did think of running a die down it (Though like you I didn't know what thread pattern it is) but as I think the threads were originally rolled rather than cut it might have weakened the integrity of the metal unless stopped as soon as good thread was encountered. I recon its an M12 x 1.25 thread, so i have ordered a die to clean up the thread, via e-bay
Post by tlight on May 28, 2011 17:34:58 GMT
Tried to clean up thread with needle file but not much luck, so ordered a die Gasket arrived from Autolink, so water bypass re-fitted... Anti roll bar tie rod arrived, so fitted, torqued and capped... So after completing the roll bars, Joseph got on and torqued all the front end and read end critical suspension joints...
Post by tlight on May 28, 2011 17:42:53 GMT
Goodridge clutch hose, in red, fitted along with male to male union Went to fit rear end cover and realised fuel tank was to high, so off came all the additional nuts... and off came the stone guard from the underside of the fuel tank (which we had nicely painted!)... added the now recommended solution of edging strip to prevent fuel hose chaffing... and ordered some fuel hose. Success, the rear cover dropped in place, needs a bit more fettling to tidy up the finish Added edging strip to the rear end, but already ran out of black plastic caps...
Post by tlight on May 28, 2011 20:05:29 GMT
Post by airforceone on May 28, 2011 20:27:49 GMT
Great Job so far guy's
Were did you get the rubber edging from, I will need some of that soon.
Post by tlight on May 28, 2011 20:40:06 GMT
Post by tlight on Jul 10, 2011 7:03:53 GMT
Have been working away from home, Goodwood FOS, etc, so no progress.
Got the loan of a wrench to re-thread the front upper wishbone joints.
Bought stainless serated nuts for suspension top mounts, stainless allen key bolts for mounting the ABS harness to the shock absorbers, 7/16UNF bolts for the seatbelt motunings, seat belt stalks (I sold mine with the leather seats as I accidently left them on in the photo so the buyer insisted they had them) and a K&N Oil Filter off e-bay £10.99.
Sold a few more parts on free e-bay listings; Front Springs £18 Door Top Moulded Trim NS £5.99 Door Top Moulded Trim OS £5.99 Rear Springs £27.99 Power Steering Pump £18.99 Passenger Internal Door Lock Surround £5.99
Post by tlight on Jul 10, 2011 19:22:59 GMT
Bargain...got a set of seats for £16 on ebay !
Post by tlight on Jul 13, 2011 20:06:51 GMT
Some progress thanks to little brother...
Cam belt completed, front brake pads fitted, rear fuel pipes installed, handbrake re-positioned, rear wishbone removed to enable repair of loose shockabsorber cage nut.
Post by tlight on Jul 14, 2011 21:55:42 GMT
Ordered some more fuel hose (bought 5m to date) from ebay, lower shock bolts and seat belt top hats both from autolink...getting closer and closer to the fitting of the engine harness...
Post by pete on Jul 15, 2011 12:13:52 GMT
you are doing a great job. having to build mine on tight budget.it looks to me that in your pictures that your top ball joints are not pressed fully into wishbone on most cars the fine splines are what holds joint in tight
Post by tlight on Jul 15, 2011 19:47:42 GMT
Pete, Thanks for the feedback. We are currently at £4K, but I have plenty of stuff still to sell, just waiting on another free listings on e-bay. Hope to tuck in under £3K. I popped the ball joints out to enable powder coating of the upper wish bones. Tim
Post by tlight on Jul 17, 2011 16:34:49 GMT
Finished crank pulley bolts & small brackets on cam belt covers, new red sparco radiator hoses in place, exhaust manifold studs and manifold cover in place, torqued the suspension tops, sorted what stalk bolts needed for seat belts, abs harness mounted at front shocks with stainess bolts, rear wishbone back in place with shockabsorder bolt/cage nut in place. Ordered all parts for fuel filler from e-bay and various fluids from mx5parts.
Post by tlight on Jul 18, 2011 20:29:30 GMT
Changed nuts on suspension tops to serrated stainless steel; Finished dress on cam belt change, but fitted thermostat housing wrong way round... Trial fit of red radiator hoses; and red servo hose; ABS harness mounted
